" /> URS RequestRouteCall format is not correct - Genesys CTI User Forum
Author Topic: URS RequestRouteCall format is not correct  (Read 2084 times)
Offline abdel
« on: July 08, 2019, 09:17:55 AM »
Agent is not able to receive calls due the behavior of URS sending RequestRouteCall with incorrect format, I think 'ACCESS' should have the extension value, not the agent value?, so the same for SIPCONN  (SIPCONN(B2B_6002)).
any help is appreciated.
@10:55:50.2550 [BSYNC] Trace: Sent
10:55:50.255 Trc 04541 RequestRouteCall received from [544] (00000009 URS_Backup 10.76.50.6:59024)
message RequestRouteCall
AttributeThisDN '904'
AttributeConnID 00bb02e1c3740322
AttributeOtherDN 'B2B_6002'
AttributeExtensions [178] 00 08 00 00..
'CUSTOMER_ID' 'Resources'
'AGENT' 'B2B_6002'
'PLACE' 'Place_B2B_1003'
'DN' '1003'
'ACCESS' 'B2B_6002'
'SWITCH' 'SIPSwitch'
'NVQ' 13
'TARGET' '?:SaveDeskTest > 0@StatServer_URS.GA'
AttributeRouteType 0 (RouteTypeUnknown)
AttributeReason [14] 00 01 01 00..
'RTR' 161
AttributeReferenceID 4646169
10:55:50.255 Int 04543 Interaction message "RequestRouteCall" received from 544 ("URS_Backup")
10:55:50.255  -- created: CRequest@481b7b0 RequestRouteCall-URS_Backup[544]/4646169
10:55:50.255:(1) SIPS:LOGBLOCK:BEGIN:REQUEST:[
10:55:50.255 +++ CIFace::Request +++
  -- new invoke
  -- thisCall by party
  Parsed: RequestRouteCall
  Numbers: +<904> -<B2B_6002>
  Calls: 482b8f0:1 none
  Parties: 904.55f6aa0-482b8f0:1
          none
  Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
  -- validate
  -- state check: ok
  CIFace: Sent CRequest@481b7b0 RequestRouteCall-URS_Backup[544]/4646169
  -- aTmCall 00bb02e1c3740322 SetCause: Distributed to B2B_6002
  FinishRequest CRequest@481b7b0 RequestRouteCall-URS_Backup[544]/4646169
  IFace stats: q=0 s=0
  -- complete
  -- NAData ClRq removed
  TNAEmulator::NotifyBackup()
@10:55:50.2550 [BSYNC] Trace: Send to backup (SIPServer8) [584]:
message EventUserEvent
attr_#1005 0
attr_#1004 255
attr_#1003 1562579750
attr_#1002 85882
attr_#1001 5
attr_#1000 131072
AttributeAgentWorkMode 0 (Unknown)
AttributeAgentStateReasonUnused 1
10:55:50.255:(1) GetRegistration::Unable to resolve number for DN:B2B_6002
10:55:50.255:(1) Number:[B2B_6002] is not internal, looking for service
10:55:50.255:(1) Selected for Dn B2B_6002(geo-loc[]:partitionId[]:cpdCapability[]): Service TrunkSIPSToALA5020_Test (geo-loc[], priority[1], capacity 0 (0% of -2))
10:55:50.255 SIPCONN(+212617465810): re-invite-called-initiated
10:55:50.255:(1) transfer re-INVITE
10:55:50.255 SIPCONN(B2B_6002): set monitor 05a04480, 05b94e7c
10:55:50.255:(1) SIPCALL(4897): add party 'B2B_6002'
  -- created party_info_tspp 562efd0
  -- created aTmParty 5ab9828
  SetRole: Destination for B2B_6002.5ab9828-482b8f0:1
  -- AddParty to 482b8f0: B2B_6002.5ab9828-482b8f0:1 after 904.55f6aa0-482b8f0:1
  CreateParty new external: B2B_6002.5ab9828-482b8f0:1
10:55:50.255:(1) Call 4897 dn B2B_6002 SetPartyId 12137
10:55:50.255:(1) SIPTR(56333): Begin step 0 - SipTransactionGetOffer(56334)
10:55:50.255 SIPCONN(+212617465810): GetOffer
10:55:50.255 SIPCONN(+212617465810): GetOffer::ReturnOffer
10:55:50.255 SIPCONN(+212617465810): NotifyOnOffer
10:55:50.255:(1) SIPTR(56334): complete
10:55:50.255:(1) SIPTR(56333): Step 0 - SipTransactionGetOffer(56334) complete
10:55:50.255:(1) SIPTR(56333): Begin step 1 - SipTransactionTransferCall(56335)
10:55:50.255 SIPCONN(B2B_6002): re-invite-null
10:55:50.255:(1) SipDialog: set monitor 05a044f4
10:55:50.255 SIPCONN(B2B_6002): main dialog 0 created
10:55:50.255 SIPCONN(B2B_6002): Local contact: '<sip:+212617465810@10.80.104.28:5060>'
10:55:50.255 SIPCONN(B2B_6002): InitiateDialog: preparing a 3pcc request
10:55:50.255:(1) add party 'B2B_6002' state
Marked as best answer by abdel on August 31, 2023, 09:39:09 PM
Offline abdel
Re: URS RequestRouteCall format is not correct
« Reply #1 on: July 08, 2019, 04:48:22 PM »
Solved, the issue was that the option use_agentid in URS was set to true, now, while routing to the target, AttributeOtherDN and ACCESS attributes use the extension instead of the agentid.
=========================Logs =============================
    AttributeConnID    00bb02e1c374607f
    AttributeOtherDN    '1003'
    AttributeExtensions    [174] 00 08 00 00..
        'AGENT'    'B2B_6002'
        'DN'    '1003'
        'ACCESS'    '1003'
        'NVQ'    13
        'RTR'    161
    AttributeReferenceID    5103751
18:22:16.756 Int 04543 Interaction message "RequestRouteCall" received from 544 ("URS_Backup")
18:22:16.756  -- created: CRequest@4818330 RequestRouteCall-URS_Backup[544]/5103751
18:22:16.756:(1) SIPS:LOGBLOCK:BEGIN:REQUEST:[
18:22:16.756 +++ CIFace::Request +++
  -- new invoke
  Numbers: +<904> +<1003>
  Calls: 48274f0:1 none
  Parties: 904.5e28768-48274f0:1
          none
  -- validate
  -- state check: ok
  CIFace: Sent CRequest@4818330 RequestRouteCall-URS_Backup[544]/5103751
  -- aTmCall 00bb02e1c374607f SetCause: Distributed to 1003
  FinishRequest CRequest@4818330 RequestRouteCall-URS_Backup[544]/5103751
  -- complete
@18:22:16.7560 [BSYNC] Trace: Send to backup (SIPServer8) [584]:
    attr_#1005    0
    attr_#1004    756
    attr_#1003    1562606536
    attr_#1002    629542
    attr_#1001    5
    attr_#1000    131072
@18:22:16.7560 [BSYNC] Trace: Sent
18:22:16.756 SIPCONN(+212617465810): re-invite-called-initiated
18:22:16.756:(1) transfer re-INVITE
18:22:16.756 SIPCONN(1003): set monitor 0625c218, 0651989c
18:22:16.756:(1) SIPCALL(28769): add party '1003'
  -- created party_info_tspp 580f0e0
  -- created aTmParty 5e28620
  SetRole: Destination for 1003.5e28620-48274f0:1
  -- AddParty to 48274f0: 1003.5e28620-48274f0:1 after 904.5e28768-48274f0:1
  CreateParty new internal: 1003.5e28620-48274f0:1
18:22:16.756:(1) Call 28769 dn 1003 SetPartyId 84060
18:22:16.756:(1) SIPTR(427758): Begin step 0 - SipTransactionTransferCall(427759)
18:22:16.756 SIPCONN(1003): re-invite-null
18:22:16.756:(1) SipDialog: set monitor 0625c28c
18:22:16.756 SIPCONN(1003): main dialog 0 created
18:22:16.756 SIPCONN(1003): Local contact: '<sip:+212617465810@10.80.104.28:5060>'
18:22:16.756 SIPCONN(1003): InitiateDialog: preparing a 3pcc request
18:22:16.756:(1) add party '1003' state
    attr_#1005    0
    attr_#1004    756
    attr_#1002    629543
    attr_#1001    1
    attr_#1000    131072
    attr_#15999    0
    attr_#16000    1
    attr_#16500    [81] 31 3d 31 0d..
    AttributeUserEvent    [16099]
18:22:16.756:(1) HA:MESSAGE:TYPE[2]: SYNCED
18:22:16.756:(1) SIPDLG[106134]: register TRN[527276]
18:22:16.756:(1) SIPDLG[106134]: TRN[527276] flags set to 0x6
18:22:16.756:(1) Sending  [588,UDP] 1013 bytes to 10.180.90.27:5060 >>>>>
INVITE sip:1003@10.180.90.27:5060 SIP/2.0
From: 212617465810 <sip:+212617465810@10.80.104.28:5060;transport=udp;user=phone>;tag=7DCB9B93-2BD5-43E7-9DA1-A2C7562E395C-211255
To: <sip:904@10.80.104.28:5060>
Call-ID: 614E4CF2-F0CC-4DDC-85CE-80CB88F9053F-173249@10.80.104.28
CSeq: 1 INVITE
Content-Length: 195
Content-Type: application/sdp
Via: SIP/2.0/UDP 10.80.104.28:5060;branch=z9hG4bK7493D4E2-062A-4194-8AB4-5969CABC56AB-362865
Contact: <sip:+212617465810@10.80.104.28:5060>
X-Genesys-CallInfo: routed
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, REFER, UPDATE
P-Charging-Vector: icid-value=mgcf--20190708172253-100020101100000121766
Max-Forwards: 67
X-Genesys-CallUUID: GFDJGTBQ4L7JNEODGA953079E0000S31
Session-Expires: 1800;refresher=uac
Min-SE: 90
Supported: uui,timer
v=0
o=- 1563472567 1 IN IP4 10.104.76.4
s=SBC call
c=IN IP4 10.104.76.4
t=0 0
m=audio 43432 RTP/AVP 8 18 101
a=sendrecv
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:18 annexb=no
18:22:16.756:(1) SipDialog: event SEND_INVITE, t=527276, s=2, r=7, m=0625c28c
18:22:16.756 SIPCONN(1003): HandleSipDialogEvent(SEND_INVITE) - filtered
18:22:16.756 SIPCONN(1003): sdp state SDP_STATE_NULL, event SDP_OFFER_SENT
18:22:16.756 SIPCONN(1003): new sdp state SDP_OFFER_SENT, event SDP_OFFER_SENT
18:22:16.756 --- CIFace::Request ---
18:22:16.756:(1) 18:22:16.756:(1) SIPS:LOGBLOCK:END:REQUEST:]
18:22:16.756:(1) SIPS:LOGBLOCK:BEGIN:SIPDATA:[
18:22:16.756:(1) Received [588,UDP] 555 bytes from 10.180.90.27:5060 <<<<<
SIP/2.0 180 Ringing
To: <sip:904@10.80.104.28:5060>;tag=2F763707-0333-4629-A945-6C5FBF072C2E-5
CSeq: 1 INVITE
Via: SIP/2.0/UDP 10.80.104.28:5060;branch=z9hG4bK7493D4E2-062A-4194-8AB4-5969CABC56AB-362865;received=10.80.104.28
User-Agent: Genesys-SIPendpointSDK/9.0.010.04 (Windows 10.0.17134)
Contact: <sip:1003@10.180.90.27:5060>
Content-Length: 0
18:22:16.756:(1) SipDialog: event CALLING_RESPROV, t=527276, s=2, r=5, m=0625c28c
18:22:16.756 SIPCONN(1003): HandleSipDialogEvent(CALLING_RESPROV)
18:22:16.756 SIPCONN(1003): Capabilities 60013f
18:22:16.756 SIPCONN(1003): reliable=0
18:22:16.756 SIPCONN(1003): store remote content
18:22:16.756 SIPCONN(1003): skip SDP pocessing [0/SDP_OFFER_SENT]
18:22:16.771:(1) routing dialog '84059' terminated
18:22:16.771  -- thisCall by party
18:22:16.771 SetContext: for party 904.5e28768-48274f0:1
18:22:16.771 +++ CIFace::Event +++
« Reply #2 on: July 08, 2019, 06:09:30 PM »
Thanks for sharing
Be sure to follow your TServer guide for some options and behavior
