" /> How to Attach/Update UData from VXML played by IRD ? - Genesys CTI User Forum
Author Topic: How to Attach/Update UData from VXML played by IRD ?  (Read 4156 times)
Offline szs5tim
« on: September 26, 2019, 08:12:08 AM »
Hi guys,
I have a IRD strategy where I use a play application block to play a vxml callflow which is just a grammar based IVR.
The outputs from the grammar menus are saved into variables at each step and I see in the MCP logs that the values are indeed assigned.
I would like to attach these variable values as user data keys so I can take them over in the IRD strategy and continue the routing based on the selection that were made.
Now, I can take over UData attached from IRD using GVP SIP headers into the VXML callflow with the following expression : session.com.genesyslab.userdata[], but I don't know how to attach user data from VXML.
I tried with the Interaction Data block using the PUT method and adding the variables but I cannot see these being attached anywhere.
In multimedia I would use _genesys.ixn.setuData.
What would be an alternative for simple VXML?
I cannot create the routing part also in Composer where I could create a workflow and simply use the User Data block because there is no ORS  configured in the Environment.
Thanks!
Offline borkokrz
Re: How to Attach/Update UData from VXML played by IRD ?
« Reply #1 on: September 26, 2019, 09:06:48 AM »
Simplest way:
Add following header on top of vxml:
<?xml version="1.0" encoding="UTF-8"?>
<vxml version="2.0" xmlns="http://www.w3.org/2001/vxml"
[b]xmlns:vg="http://www.voicegenie.com/2006/vxml21-extension"[/b]
xmlns:genesys="http://www.genesyslab.com/vxml/2.0/ext/20020430">
then per example inside block tag add something like this:
      <vg:send async="false" bodyexpr="'[b]key=value[/b]'" contenttype="application/x-www-form-urlencoded"/>
« Reply #2 on: September 26, 2019, 09:21:54 AM »
You can use namelist parametr within "exit" element of your VXML to post user data as KVP.
Offline szs5tim
« Reply #3 on: September 26, 2019, 10:13:03 AM »
@Kubig
As far as I know is only for sub workflows or in a sub call flow when you want to return values to the main call flow.
How would that attach KVPs to my conn id in SIP Server?
When I attach something from IRD and to be able to take it over in VXML I had to configure on SIP Server and the DN where I map Tlib to SIP messages the mapping of User data to SIP Headers.
Since then, I can take over attached data.
Now the question is how to do the same but the other way around, from VXML so I can attach a KVP and retrieve it in IRD with UData['kvp_name'] for example.
None of the above proposals worked.
Marked as best answer by szs5tim on October 11, 2019, 08:29:18 PM
« Reply #4 on: September 26, 2019, 12:37:25 PM »
You are wrong. The mapping to the KVP structure is working by default without any further configuration
Offline szs5tim
« Reply #5 on: September 26, 2019, 12:49:56 PM »
Well, Kubig,  I tried that.
Even with using a Send Data block without any success.  :(
I added here my Composer project, the IRD strategy and some logs with one example call having conn id: 015002e85d40f10a
https://wetransfer.com/downloads/c217228a594b3396dde0765710120c4620190926124656/77ac420f4c1e57d1bd59b3426c7e64d820190926124656/213ae3
If you can have look I would really appreciate it.  ;D
« Reply #6 on: September 26, 2019, 05:57:01 PM »
Have you configured MCP and SIP server to send attach data?
Can you share MCP logs?
Enviado de meu SM-G9650 usando o Tapatalk
Offline szs5tim
« Reply #7 on: October 11, 2019, 07:31:44 AM »
At the end it was a mistake I made in the flow.
I used grammars and my GRXML was not correctly generated(oh, eclipse  :o) and the call never passed my SendData block from the VXML.
Once I fixed that, everything worked fine.
Thanks guys!
