" /> Limiting the Shared workbin count in Agent/Wde level - Genesys CTI User Forum
Author Topic: Limiting the Shared workbin count in Agent/Wde level  (Read 1718 times)
Offline CASANOVA
« on: February 13, 2020, 06:38:18 PM »
Dear All,
Need your suggestion. Can we limit shared workbin count on agent or wde level. I could see max-workbin-interaction on interaction server level.
Is there any possibility that we can control the same on Agent/WDE level
Re: Limiting the Shared workbin count in Agent/Wde level
« Reply #1 on: February 14, 2020, 06:02:35 PM »
What do you mean? Why you want to limit? Better to monitor the workbin and if he has items older than x days took an action
Why make the agents life harder?
Offline CASANOVA
« Reply #2 on: February 14, 2020, 06:20:14 PM »
Presently the count is 600 in our environment for shared workbins. We just want to reduce the count.
Is there any way i can limit shared workbin count at Agent/Ade level ??
We have a huge mail flow in one of our Mailboxes due to that supervisors are not able to manage effectively with shared workbins.
« Reply #3 on: February 14, 2020, 06:35:10 PM »
No way to limit, unless via strategy you do as said something periodically with old items.
Limit is not going to solve your problem for what you explain, it is only going to get worst
Offline CASANOVA
« Reply #4 on: February 14, 2020, 07:03:15 PM »
Thanks Cavagnaro.
Thanks for your time and suggestion. Will try in strategy level.
Thanks.
