" /> SMPP Gateway Simulator for SMS testing? - Genesys CTI User Forum
Author Topic: SMPP Gateway Simulator for SMS testing?  (Read 4094 times)
Offline abudwill
« on: May 07, 2020, 07:37:52 PM »
Hi guys,
Does anyone have hands on/real world experience using some sort of SMPP Gateway simulator when developing/integrating SMS?
I will eventually have a true SMPP integration with a carrier.  But before that happens I want to be able to reasonably develop some routing strategies and test my overall system/setup.  To do this I would need to use some sort of SMPP gateway simulator that I could point Genesys SMS server to.
Has anyone used such a product?  If so, what was it and any pros/cons?
Regards,
Andrew
Re: SMPP Gateway Simulator for SMS testing?
« Reply #1 on: May 07, 2020, 09:19:56 PM »
I had done some tests with:
[url=http://www.seleniumsoftware.com/user-guide.htm]http://www.seleniumsoftware.com/user-guide.htm[/url]
At least for basic tests did work
Offline abudwill
« Reply #2 on: May 07, 2020, 09:26:10 PM »
Thank you, looks promising!
Offline abudwill
« Reply #3 on: May 08, 2020, 03:55:35 PM »
Looks like SMPPSim is no longer available. I have reached out to the vendor, but doesn't look so promising anymore! I have found some small homegrown developed SMPP simulators which I may take and expand on for my needs. Before I go there, anyone else have hands on with an SMPP simulator?
« Reply #4 on: May 08, 2020, 04:36:17 PM »
Wohhh so bad... I have the last version and includes the source code. If you are interested
Offline abudwill
« Reply #5 on: May 11, 2020, 06:29:50 PM »
Sent you a PM. And I owe you one.
« Reply #6 on: May 11, 2020, 06:46:20 PM »
Sent
https://we.tl/t-9r2M8O9zoT
Offline abudwill
« Reply #7 on: May 11, 2020, 07:23:38 PM »
Received, thank you! You just made my life so much easier...
Offline abudwill
« Reply #8 on: May 15, 2020, 05:49:14 PM »
I wanted to follow up and share that this worked well for my needs and was very easy to setup. Since this is just an SMPP gateway simulator, it is not really possible to have an SMS conversation between two endpoints without additional setup and software. But this makes sense. Genesys SMS server would be considered an ESME client and would deliver messages to its clients (agents on an agent desktop). Simulator provides several ways to inject mobile originated (MO) messages destined for the ESME (in my case Genesys SMS server). However if agent responds to a message, the message gets held in an internal SMPP simulator queue since there is not a second/destination ESME for the message to be delivered to. A person would need to connect/wire up a second/additional ESME client for response messages to be sent to. Or in poor mans land, a second instance of Genesys SMS server would work fine so long as the MSISDNs (x-smpp-address-range setting on SMS server) is setup and registers with the simulator properly. At this point two instances of WDE could be used to simulate two cell phones and send either page mode messages back and forth or engage a session mode. All of this discussed here still adheres to SMPP v3.4 spec, even the hacky setup of two Genesys SMS servers / WDE to simulate cell phones.
Offline vma
« Reply #9 on: April 24, 2023, 01:00:59 PM »
[quote author=cavagnaro link=topic=11604.msg52898#msg52898 date=1589222780]
Sent
Hi cavagnaro,
any chance you still have this simulator after all these years?
Thanks!
« Reply #10 on: April 24, 2023, 09:13:42 PM »
Yes I do
https://we.tl/t-mIu7rlrCkF
Offline boxen
« Reply #11 on: April 26, 2023, 04:35:25 AM »
[quote author=cavagnaro link=topic=11604.msg55251#msg55251 date=1682370822]
Yes I do
Thanks for sharing. Below are the MD5 hashes of SMPPSim.zip's content and the archive itself. Just in case someone finds a download elsewhere in the future, these are the checksum hashes I received from the SMPP file.
Algorithm      Hash        Path
MD5            02D276D1E363F736DE4F5A4EB99E8FF9                                      D:\SMPPSim.zip
