" /> Genesys Pulse log out - Genesys CTI User Forum
Author Topic: Genesys Pulse log out  (Read 1936 times)
Offline marmota
« on: June 09, 2020, 10:21:20 AM »
Hi there!
We've just implemented Pulse and faced an issue - sometimes it's logged out to login page. Hence launched wallboard stops and welcome login page is displayed.
It doesn't seem like a session timeout as it happens in different periods - sometimes in couple of hours, sometimes in a day or even more.
Have anybody faced same issue?
What I assume can be done:
- resolve the issues itself (maybe there is some fix known?)
- put selected wallboard to unathorized zone so that it doesn't ask to login (is it possible?)
Any ideas?
Re: Genesys Pulse log out
« Reply #1 on: June 09, 2020, 10:03:49 PM »
Disable session logout? That can be done at level app
[url=https://docs.genesys.com/Documentation/System/latest/SDG/Inactiv]https://docs.genesys.com/Documentation/System/latest/SDG/Inactiv[/url]
Offline marmota
« Reply #2 on: June 09, 2020, 10:18:27 PM »
Thanks for the option!
Not sure it will be accepted due to security possible issues but will investigate.
« Reply #3 on: June 10, 2020, 02:30:48 AM »
Well...if you consider a no login option...then no clue which security exactly you are asking  :P
