" /> Not getting a KVP in Speechminer - Genesys CTI User Forum
Author Topic: Not getting a KVP in Speechminer  (Read 2605 times)
Offline genesyslearner
« on: June 10, 2020, 11:06:31 AM »
Hi Experts,
I am facing an issue with a KVP "A" getting populated in Speechminer. As far as i am aware, Speechminer picks all the KVP's from G_USERDATA_HISTORY table in ICON DB. Please let me know if the understanding is not correct.
We are not getting this KVP in ICON DB itself but from the SIP server logs everything seems perfect. UserData contains the "A" KVP and is being sent to ICON from SIP.
Could you suggest what could be the issue as i am failing to understand?
Re: Not getting a KVP in Speechminer
« Reply #1 on: June 10, 2020, 02:57:25 PM »
Check ICON's configuration whether it's configured to collect all KVP at all. If yes, check ICON logs to see what happened on that level
Offline hsujdik
« Reply #2 on: June 10, 2020, 03:04:58 PM »
You have to specify which attach data ICON stores to the database on the file adata_spec.xml located in ICON's installation folder. Once the file is changed, ICON needs to be restarted
« Reply #3 on: June 10, 2020, 03:38:48 PM »
[quote author=hsujdik link=topic=11625.msg52953#msg52953 date=1591801498]
If you configure ICON for GIR in respect to the deployment guide than there is no need to configure ICON adata_spec.xml file at all.
« Reply #4 on: June 10, 2020, 06:30:54 PM »
Well...just checked out documentation and this is new...previously you did have to configure the XML file.
Offline hsujdik
« Reply #5 on: June 10, 2020, 07:16:42 PM »
[quote author=Kubig link=topic=11625.msg52954#msg52954 date=1591803528]
Nice... I just reviewed how it is made. I was thinking on the ICON side. The way the configuration is shown for GIR, the attach data should be stored in G_CUSTOM_DATA_S table, instead of G_USERDATA_HISTORY.
@genesyslearner: Perhaps you should check that other table and those configurations on CustomStates section of ICON (https://docs.genesys.com/Documentation/CR/latest/Solution/ICON)
Offline Janis
« Reply #6 on: June 10, 2020, 07:57:31 PM »
[quote author=cavagnaro link=topic=11625.msg52955#msg52955 date=1591813854]
Still prefer to explicitly set kvp’s needed in xml file. Do not like to have huge ICON db with unused data. GIR guide teaches us a lazy aproach.
« Last Edit: June 10, 2020, 07:59:05 PM by Janis »
