" /> WDE Error for Twitter Interactions - Genesys CTI User Forum
Author Topic: WDE Error for Twitter Interactions  (Read 1823 times)
Offline GeloJ07
« on: October 09, 2020, 01:00:40 PM »
Hi everyone!
I have encountered a problem with Twitter interactions. In particular, when the interaction comes in the WDE bar, at the press of the Reply all button (or Reply, Retweet, Direct message), an error on the WDE logs appear:
[i]    [b]1] ERROR .BootstrapController - Application.DispatcherUnhandledException
System.NullReferenceException: Object reference not set to an instance of an object.
  at Genesyslab.Desktop.Modules.Twitter.Controls.InboundTweetCtrl.menuItemReplyToAll_Click(Object sender, RoutedEventArgs e) in z:\Base.Mercurial.Project\SocialMediaPlugin\Genesyslab.Desktop.Modules.Twitter\Controls\InboundTweetCtrl.xaml.cs:line 1621
  at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
  at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
  at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
  at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
  at System.Windows.Controls.Primitives.ButtonBase.OnClick()
  at System.Windows.Controls.Button.OnClick()
  at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
  at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
  at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
  at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
  at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
  at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
  at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
  at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
  at System.Windows.Input.InputManager.ProcessStagingArea()
  at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
  at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
  at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
  at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
  at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
  at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)[/i][/b]
What could it be?
How can I fix it?
Thanks in advance
Re: WDE Error for Twitter Interactions
« Reply #1 on: October 09, 2020, 06:49:47 PM »
Weird... Open an eSR with Genesys better.
Check you are using last version of the plug-in
