" /> Composer Record timeout property variable - Genesys CTI User Forum
Author Topic: Composer Record timeout property variable  (Read 1460 times)
Offline ricardo.sosa
« on: December 18, 2020, 08:52:16 AM »
In a node Record in Composer, is there a way to set a variable timeout?
Same for "Final Silence", "Max Duration", "Min Duration"... I guess it would work the same way, if it is possible.
Thank you.
Re: Composer Record timeout property variable
« Reply #1 on: December 22, 2020, 11:50:48 AM »
Replying to myself to add new possibilities:
What about vxml? Is there a way to set timeout to a record from a variable?
Thank you again.
Marked as best answer by ricardo.sosa on January 13, 2021, 10:44:15 PM
« Reply #2 on: January 13, 2021, 08:43:49 AM »
My solution:
- I have created a subflow with a record node (and a couple assign to pass back the result of the record in case of exceptions).
- Passed in and out the parameters that I need.
- Generated vxml.
- Copy this file to a jsp file.
- Received the param for timeout (and rest of times)
- Substitute actual values in record attributes for the params received.
- Main.vxml is calling this new jsp file as a subdialog.
I hope that this helps.  :)
« Reply #3 on: January 13, 2021, 03:02:27 PM »
Thanks for sharing your solution  8) ;D
