" /> Is there a way to trigger the alarm if SIP server did not create new Connid - Genesys CTI User Forum
Author Topic: Is there a way to trigger the alarm if SIP server did not create new Connid  (Read 1867 times)
Offline kalakshmanakumar
If SIP server did not create new connid for last 10 minutes SCS need to trigger alarm.
Thanks in advance for your response.
Regards,
Lakshmanakumar Krishnasamy
Offline genesysguru
    • Genesys Guru Blog
Are you trying to check is a SIP server is still receiving calls? If so just use the SIPS HTTP Monitoring API:
https://docs.genesys.com/Documentation/SIPS/8.1.1/Dep/HTTPMonitoring
Craig
Offline gen_rtfm
Are you trying to monitor the health of the system or that agents are 'doing their job'?
For sip server you could use the alarms for DN out of service perhaps, and active trunk oos detection. I don't know the log entries by heart, but they should be able to provide a monitoring of the system health and raise alarms via scs.
Agents though, I'd do that by statserver. Though you can't raise an alarm to scs you could have thresholds and triggers in a client to raise awareness. Not a perfect fit, ideally you'd need a custom SS client that is always on, ccpulse requires a desktop app to be active for threshold reaction scripts.
I have seen people have an always-on PC running ccpulse for those kinds of alarms... Don't know if I'd advise to do that though.
Br
Skickat från min Mi MIX 3 5G via Tapatalk
« Last Edit: February 14, 2021, 08:47:55 AM by gen_rtfm »
Offline hsujdik
Check if the option "TServer\sip-pass-check" suits your needs
Thanks for your Reponses.
