" /> gvp - google tts trouble - Genesys CTI User Forum
Author Topic: gvp - google tts trouble  (Read 1376 times)
Offline vanero
« on: April 15, 2021, 08:53:37 AM »
Hi guys!
I'm trying to set up gvp and google , but i'm doing something wrong(
I did everything as written in the post (http://www.sggu.com/smf/index.php?topic=11559.10) installed the last mсp (9.0.046.06) create RAP applications VP_MCP_GRPC_ASR_900 and VP_MCP_GRPC_TTS_900
when configure mcp.
There are no attempts to connect with google in the mcp logs, there are no errors either.
when trying to use the asr\tts engines in the logs, this:
Trc 20001 INFO 015A0207-10002BC1-tts-GTTS-3 6800 06100000 Warning: Cannot get the Attributes for opensession using engine: GTTS
Std 20003 WARN 015A0207-10002BC1-tts-GTTS-3 6800 061007DC Unable to open a session using engine GTTS in MRCPv1 module. Please check speech resource provision and application to make sure the right engine name and protocol version are specified -(return code: -3)
DBUG 00000000-00000000 6800 06100000 VRMCommon.h:142 sdpobjrelref 78e81380 refcount=1
DBUG 015A0207-10002BC1-tts-GTTS-3 6800 06A007E2 MRCPClientAdaptor.C:1378 OpenSession failed with MRCPV1 Protocol
DBUG 015A0207-10002BC1-tts-GTTS-3 6800 06A00000 MRCPClientAdaptor.C:1367 CallUUID=[S7T49JL5U94J35FV5BTNIPB5OS0000VA] TenentID=[POKK]
DBUG 015A0207-10002BC1 6800 08500000 SessionConfiguration.C:86 SessConfig::GetValue - Param=[vrm.policy.authorizedttsengines]; Value=[]; [Local]
Std 20003 WARN 015A0207-10002BC1-tts-GTTS-3 6800 06B007E9 Unable to open a session using engine GTTS in MRCPv2 module. Please check speech resource provision and application to make sure the right engine name and protocol version are specified -(return code: -3)
DBUG 015A0207-10002BC1-tts-GTTS-3 6800 06A007E2 MRCPClientAdaptor.C:1378 OpenSession failed with MRCPV2 Protocol
DBUG 015A0207-10002BC1-tts-GTTS-3 6800 06100000 DTMFRecognitionClientLibrary.cxx:202 DTMFRecognitionClientLibrary::OpenSession
Trc 20001 INFO 015A0207-10002BC1-tts-GTTS-3 6800 06100000 DTMFRecognitionClientLibrary::OpenSession sessionType=1, engineName=GTTS. Not a valid DTMF Session
DBUG 015A0207-10002BC1-tts-GTTS-3 6800 06A007E2 MRCPClientAdaptor.C:1378 OpenSession failed with MRCP_DTMFRECOGNIZER Protocol
Std 20003 WARN 015A0207-10002BC1-tts-GTTS-3 6800 06A007E2 Failed to open an MRCP Session using any of the MRCP Clients.
Std 22017 EROR 015A0207-10002BC1-tts-GTTS-3 6800 06A007E1 OpenSession failed with all MRCP Client Instances.
need advice on what to do))
full mcp log: https://shrib.com/?v=nc#Baker4w59nrJ
« Last Edit: April 15, 2021, 09:09:15 AM by vanero »
