" /> ORS - Current handling sessions or request - Genesys CTI User Forum
Author Topic: ORS - Current handling sessions or request  (Read 1948 times)
Offline genesysnoob
« on: August 13, 2021, 06:28:54 PM »
Is there a way to find how many requests or sessions ors is handling
For the below interaction types, where can I see in the logs
Voice
Email
Chat
Iwd
Offline gen_rtfm
Re: ORS - Current handling sessions or request
« Reply #1 on: August 13, 2021, 06:53:19 PM »
Not exactly what you asked for but ORS has some views for status/statistics that might be useful:
https://docs.genesys.com/Documentation/OS/latest/Developer/ExternalIntf#Orchestration_Platform_Status
Also check the "tip" at the top of the page, there might be more information in the built-in help; additional views etc.
Br
Skickat från min Mi MIX 3 5G via Tapatalk
Offline genesysnoob
« Reply #2 on: August 16, 2021, 05:00:01 PM »
Sorry I was not clear
Let’s say you have a staging / testing environment Abe you the only one testing
You dialed the test number and ors is processing the call .
If you pull the latest ors logs, will it say anywhere it’s processing one call only?
I am interested in knowing current number or calls ors is processing
Offline gen_rtfm
« Reply #3 on: August 16, 2021, 05:56:15 PM »
Not sure, if you check the .lms file in the install directory you should see if there are any specific log entries that count ongoing/live sessions.
There is an scxml statistic view in ors web interface that show a count of created and exited sessions which can be used to determine the same thing. I can give you an url for it tomorrow if you're interested.
Br
Offline genesysnoob
« Reply #4 on: August 16, 2021, 09:28:19 PM »
Please share when you get a chance
Offline gen_rtfm
« Reply #5 on: August 17, 2021, 08:50:56 AM »
Check out http://[ors server]:[http port]/server/scxmlStat
For an overview of available views, check
http://[ors server]:[http port]/server?core
And [ors server] should be replaced with FQDN or IP of your server running ors, [http port] with the http port configured in your ors application object.
Br
« Reply #6 on: August 18, 2021, 12:35:45 PM »
At URS logs you can find:
  _I_I_ [25:01] script **ScxmlServer usage +1=12
Like strategies being executed
Offline genesysnoob
« Reply #7 on: August 20, 2021, 01:48:52 PM »
[quote author=gen_rtfm link=topic=12093.msg54231#msg54231 date=1629190256]
Br
thank you.. this helped.
i looked into each link on the http site and i couldn't find the current call count..
the above link provided call list but not the count...
Offline genesysnoob
« Reply #8 on: August 20, 2021, 01:50:27 PM »
[quote author=cavagnaro link=topic=12093.msg54237#msg54237 date=1629290145]
thank you.. this gave me the count gtom urs logs
