" /> Composer - OCS_URI - Genesys CTI User Forum
Author Topic: Composer - OCS_URI  (Read 1399 times)
Offline Gaia
Composer - OCS_URI
« on: August 17, 2021, 03:48:24 PM »
hi all,
I am using  in composer the block "update record" , but I have an error
event error.com.genesyslab.composer.servererror:1|AppState.OCS_URI property is not set.
the MCP logs shows that I received only X-Genesys-GSW_RECORD_HANDLE and X-Genesys-GSW_RECORD_URI is missed
In composer is defined like this :
OCS_Record - Value: getCallflowOCSRecord()
OCS_RecordURI - Value: getCallRecordURI()
OCS_Record - Value: getCallflowOCSURI()
41 / 5000
Is there a setting to do on the ocs side to send this attached data ? ::)
Thank you
Re: Composer - OCS_URI
« Reply #1 on: August 18, 2021, 12:13:03 PM »
Have you enabled OCS HTTP interface?
Offline Gaia
« Reply #2 on: August 23, 2021, 08:29:27 AM »
hi cavagnaro
??? good question , no
but I added http port in configuration.
« Reply #3 on: August 23, 2021, 03:06:53 PM »
Ok so now you would need a OCS restart
