" /> Calls priorities in VTO queues - Genesys CTI User Forum
Author Topic: Calls priorities in VTO queues  (Read 3063 times)
Andy
Does anybody know how to implement calls prioties in queues realized on VTO ?
Clio
hat is wrong with using Priority command?
Marked as best answer by on May 15, 2025, 04:38:07 PM
Kevin
  • Undo Best Answer
  • The only thing to note about Priority: in URS 6.x, it does not work for Agent or Place Groups.
    The workaround is to do a SelectDN on the Agent or Place Group, set the priority, then queue the call to the list of Agents.
    There are additional tickets on the Genesys Support Knowledgebase discussing this issue.
