" /> Recommendations for installing LCA on Linux centos 7 - Genesys CTI User Forum
Author Topic: Recommendations for installing LCA on Linux centos 7  (Read 2028 times)
Offline efrainclg95
« on: December 17, 2021, 05:34:50 AM »
Dear expert friends
First of all thank you for your time and support in this forum:
I am installing the genesys platform and some components have to be on a Linux Centos 7 to be more specific, I have problems with the LCA since it cannot connect to the SCS.
I already have the libraries described in the Genesys manual (deployment) installed on the Linux server, when executing ./run in the log it mentions that the LCA cannot connect to the SCS.
I wanted to know if it is a requirement that this linux centos 7 server be a member of Active Directory (AD), since the rest of the servers are windows and belong to an AD domain.
Could you install centos 7 just by adding the ip and names of the servers in your host file?
What do you recommend or what best practices do you recommend?
Thanks for your kind support.
Offline Janis
Re: Recommendations for installing LCA on Linux centos 7
« Reply #1 on: December 17, 2021, 12:41:21 PM »
SCS is connecting to LCA. LCA is just waiting for this connection. SCS will try to connect if there is a host object created in genesys config.
Offline efrainclg95
« Reply #2 on: December 23, 2021, 02:21:47 PM »
Thank you very much for the scope, I was able to install on Linux, disable selinux and then firewalld, and with this the LCA was recognized by the SCS, finally I installed the config server and everything OK
thank you, happy holidays
