" /> Workspace-Cannot Resolve Queue For submit error (Facebook outbound interaction) - Genesys CTI User Forum
Author Topic: Workspace-Cannot Resolve Queue For submit error (Facebook outbound interaction)  (Read 5507 times)
Offline Amr
Hello Dears,
I am configuring Facebook channel interactions entered successfully and interaction reach to agent on WDE normally with no errors but when I am trying to comment on any entered interaction it gives me the below error:
[b]Cannot Resolve Queue For submit[/b]
please consider i have added wde options as below:
[u]facebook.default-queue=Facebook Outbound Queue[/u]
[u]facebook.outbound-queue=Facebook Outbound Queue[/u]
Do you have any idea to deal with this issue just keep in mind that i have a twitter channel and was have the same issue but whine i added the wde options of twitter it worked normally
Thanks in advance
And those Queues exist?
What does IXN mentions?
Offline Amr
Hello cavagnaro
Yes Exist
I see This error in IXN logs
2022-02-01T14:30:45.792 Trc 23102 Cannot resolve queue for submit while processing request 'RequestSubmit' from client 18:3020, reference id: 37
2022-02-01T14:30:45.792 Trc 26019 Sending message 'EventError' ('126') to client 'Facebook_Test' - Agent application:18:3020 through proxy 'WDE_Digital_mosha' - Proxy:17:3020, message attributes:
attr_ref_id [int] = 37
attr_prxy_client_id [int] = 18
attr_error_code [int] = 91
attr_error_desc [str] = "Cannot resolve queue for submit"
Are you sure that the Queue has the exact same name? Seems IXN has no clue on that Queue. If you are 100% sure that names match, then try a IXN restart
Offline Amr
Hello cavagnaro
First of all Thank you for your interest
and here is the answers of your questions
[b]Are you sure that the Queue has the exact same name?[/b]
Yes i am very sure.
[b]Seems IXN has no clue on that Queue.[/b]
I agree with you however I see the queue name on IXN Logs as below
  [i]'IN_TARGETS' [list] = (size=28)
      'Facebook Stop Queue' [str] = ""
  'OUT_TARGETS' [list] = (size=32)
      'Facebook Outbound Queue' [str] = ""[/i]
[b]If you are 100% sure that names match, then try a IXN restart[/b]
I have done the restart with no change.
Thanks in advance
[/list][/list]
WDE has a connection to IXN, correct?
Offline Amr
Hello
Yes it has.
These queues have a strategy attached, correct in the BP?
If so, in IXN logs you should see a log where IXN does a query to extract the first interactions from it.
Is it happening?
Offline Amr
Hello cavagnaro
[b]These queues have a strategy attached, correct in the BP?[/b]
Yes Correct
[b]in IXN logs you should see a log where IXN does a query to extract the first interactions from it.
Is it happening?[/b]
I am not sure I understand you but in bellow the logs of ixn when i try to comment on an interaction let me know if you subsect any issues in this lines  also if this not related with your question please do you have any keywords to search with in IXN logs also i can provide ixn log file throw a mail just if you want
2022-02-01T21:45:49.222 Trc 26015 Received message 'RequestSubmit' ('101') from client 'WDE_Digital_mosha' - Proxy:90:3952, message attributes:
attr_media_type [str] = "facebook"
attr_itx_type [str] = "Outbound"
[b]attr_itx_subtype [str] = "OutboundReply"[/b]
attr_prnt_itx_id [str] = "045H6831Y5N8V001"
attr_tenant_id [int] = 1
attr_is_online [int] = 0
attr_received_at [str] = "0001-01-01T00:00:00Z"
attr_in_queues [list, size (unpacked)=129] =
attr_out_queues [list, size (unpacked)=56] =
attr_user_data [list, size (unpacked)=8529] =
  'ServiceObjective' [int] = 0
  'RVQDBID' [str] = "722"
  'RTargetAgSelDBID' [str] = "688"
  'RTargetPlSelDBID' [str] = "647"
  'RTenantDBID' [str] = "1"
  'CustomerSegment' [str] = "default"
  'ServiceType' [str] = "default"
  'Screen_Sentiment_ScreenRuleName' [str] = ""
  'Screen_Sentiment_CtgName' [str] = ""
  'Screen_Sentiment_CtgRelevancy' [str] = ""
  'Screen_Actionability_ScreenRuleName' [str] = ""
  'Screen_Actionability_CtgName' [str] = ""
  'Screen_Actionability_CtgRelevancy' [str] = ""
  'Classify_Sentiment_CtgName' [str] = ""
  'Classify_Sentiment_CtgRelevancy' [str] = ""
  'Classify_Sentiment_CtgId' [str] = ""
  'Classify_Actionability_CtgId' [str] = ""
  'Classify_Actionability_CtgRelevancy' [str] = ""
  'Classify_Actionability_CtgName' [str] = ""
  'IxnAlreadyCreatedInUCS' [str] = "1"
  'RPVQID' [str] = "RKEMHF81PH473B3HGH7MMUUI2S005BAD"
  'IW_OwnerId' [int] = 688
  'desktop_ParentItxData' [list] = (size=4429)
      '_facebookComments' [list] = (size=4)
      '_facebookXML' [str] = "<com.genesyslab.mcr.facebook.monitor.ResultsStreamWithComments xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <stream>
    <post__id>107124634230288_453923399550408</post__id>
    <viewer__id>248146..." [truncated]
      'desktop_actionable' [str] = "1"
      'desktop_sentiment' [str] = "Neutral"
      'desktop_expand' [str] = "1"
      '_umsChannelInfo' [list] = (size=1226)
        'channel-facebook-egyptpost-service-test-monitor-generic' [list] = (size=1162)
            '_facebookSourceId' [str] = "107124634230288"
            '_facebookSourceNickName' [str] = "IST Networks Customer Care"
            '_facebookSourceObjectType' [str] = "com.genesyslab.mcr.facebook.fql.Page"
            '_facebookUserScreenName' [str] = "IST Networks Customer Care"
            '_facebookUserName' [str] = "IST Networks Customer Care"
            '_facebookUserImageURL' [str] = "https://scontent-lcy1-1.xx.fbcdn.net/v/t1.6435-1/cp0/p50x50/87953430_107124760896942_7139464496224927744_n.png?_nc_cat=109&ccb=1-5&_nc_sid=dbb9e7&_nc_ohc=e_TiSmJGBRoAX-Nlaq9&_nc_ht=scontent-lcy1-1.xx&edm=AOf6bZoEAAAA&oh=00_AT8VVrfpuTkVfjMHqGPN7x2EqqaGTSjaY..." [truncated]
            '_facebookSourceXML' [str] = "<com.genesyslab.mcr.facebook.fql.Page>
  <page__id>107124634230288</page__id>
  <name>IST Networks Customer Care</name>
  <pic__small>https://scontent-lcy1-1.xx.fbcdn.net/v/t1.6435-1/cp0/p50x50/87953430_107124760896942_7139464496224927744_n.png?_nc_cat=109..." [truncated]
      '_facebookIsLiked' [str] = "True"
      '_facebookIsHidden' [str] = "null"
  'desktop_OutboundItxType' [str] = "SolicitedComment"
  'desktop_OutboundCreatedAt' [str] = "1643744749"
  'FromAddress' [str] = "IST Networks Customer Care"
  '_umsFromAddr' [str] = "107124634230288"
  '_umsInboundIxnSubmittedBy' [str] = "S_DMS_P"
  '_umsChannelMonitor' [str] = "channel-facebook-egyptpost-service-test-monitor-generic"
  '_umsChannel' [str] = "channel-facebook-egyptpost-service-test"
  '_facebookSubmitType' [str] = "comment"
  '_facebookPostId' [str] = "107124634230288_453923399550408"
  'desktop_AgentEmployeeId' [str] = "mosha"
  'Subject' [str] = "Reply: Again Again"
  'ContactId' [str] = "000BNaGV65HSYR6J"
attr_prxy_client_id [int] = 91
attr_ref_id [int] = 43
2022-02-01T21:45:49.222 Trc 23102 Cannot resolve queue for submit while processing request 'RequestSubmit' from client 91:3952, reference id: 43
2022-02-01T21:45:49.222 Trc 26019 Sending message 'EventError' ('126') to client 'Facebook_Test' - Agent application:91:3952 through proxy 'WDE_Digital_mosha' - Proxy:90:3952, message attributes:
Thanks for interest[/list][/list][/list][/list]
You can search for something like this:
[code]Dbg 25030 Database request sent: DAP:'DAP_IXN'(0), request id: '122098158', dbchannel stack id: '2', interaction id:'', sql statement: [select id,server_id,parent_id,tenant_id,is_online,is_locked,snapshot_place_id,state,queue,media_type,type,subtype,agent_id,agent_group_id,place_id,place_group_id,submitted_by,TO_CHAR(received_at, 'YYYY-MM-DD HH24:MI:SS') AS received_at_,TO_CHAR(submitted_at, 'YYYY-MM-DD HH24:MI:SS') AS submitted_at_,TO_CHAR(delivered_at, 'YYYY-MM-DD HH24:MI:SS') AS delivered_at_,TO_CHAR(placed_in_queue_at, 'YYYY-MM-DD HH24:MI:SS') AS placed_in_queue_at_,TO_CHAR(moved_to_queue_at, 'YYYY-MM-DD HH24:MI:SS') AS moved_to_queue_at_,workbin,destinations,TO_CHAR(abandoned_at, 'YYYY-MM-DD HH24:MI:SS') AS abandoned_at_,TO_CHAR(scheduled_at, 'YYYY-MM-DD HH24:MI:SS') AS scheduled_at_,cache,submit_seq,place_in_queue_seq,TO_CHAR(held_at, 'YYYY-MM-DD HH24:MI:SS') AS held_at_,TO_CHAR(assigned_at, 'YYYY-MM-DD HH24:MI:SS') AS assigned_at_,TO_CHAR(completed_at, 'YYYY-MM-DD HH24:MI:SS') AS completed_at_,assigned_to,external_id,priority,service_objective,mailbox,from_personal,from_address,subject from interactions where id in (select id from (select id from interactions where state = 0 and is_locked = 0 and queue = 'NDR' and tenant_id = 101 order by received_at, id) where rownum <= 200) order by received_at, id for update][/code]
Of course, just search for your Queue name, in my case is "NDR"
Offline Amr
Hello cavagnaro,
I see the following requests with the same request id = "11702"
Note: Queue name in my case named = "Facebook Outbound Queue"
2022-02-02T05:01:26.587 Dbg 25030 [b]Database request sent: DAP:'IXN_DAP_ODBC'(4), request id: '11702'[/b], dbchannel stack id: '0', interaction id:'(null)', sql statement: [select top 200 id,server_id,parent_id,tenant_id,is_online,is_locked,snapshot_place_id,state,queue,media_type,type,subtype,agent_id,agent_group_id,place_id,place_group_id,submitted_by,received_at,submitted_at,delivered_at,placed_in_queue_at,moved_to_queue_at,workbin,destinations,abandoned_at,scheduled_at,cache,submit_seq,place_in_queue_seq,held_at,assigned_at,completed_at,assigned_to,external_id,priority,service_objective,facebookcommentid,facebookinbufferbeforetarget,facebookinqueueattarget,facebookpostid,twitterinbufferbeforetarget,twitterinqueueattarget,twittergroupid,dms_app_name,flexible_properties from interactions with (updlock) where state = 0 and is_locked = 0 and queue = 'Facebook Outbound Queue' and tenant_id = 1 order by received_at, id ]
2022-02-02T05:01:26.587 Dbg 25032 [b]Database request executed: DAP:'IXN_DAP_ODBC'(4), request id: '11702',[/b] dbchannel stack id: '0', interaction id:'(null)', sql statement: [select top 200 id,server_id,parent_id,tenant_id,is_online,is_locked,snapshot_place_id,state,queue,media_type,type,subtype,agent_id,agent_group_id,place_id,place_group_id,submitted_by,received_at,submitted_at,delivered_at,placed_in_queue_at,moved_to_queue_at,workbin,destinations,abandoned_at,scheduled_at,cache,submit_seq,place_in_queue_seq,held_at,assigned_at,completed_at,assigned_to,external_id,priority,service_objective,facebookcommentid,facebookinbufferbeforetarget,facebookinqueueattarget,facebookpostid,twitterinbufferbeforetarget,twitterinqueueattarget,twittergroupid,dms_app_name,flexible_properties from interactions with (updlock) where state = 0 and is_locked = 0 and queue = 'Facebook Outbound Queue' and tenant_id = 1 order by received_at, id ]
2022-02-02T05:01:26.587 Dbg 27124 [b]No interactions selected[/b] (connection ID: 4, prototype: 4, request ID: 11702, interaction ID: 'NULL')
Thanks in advance
Imho, it looks more like WDE issue (attr_queue is missing) - did you check WDE logs?
[quote author=Amr link=topic=12243.msg54663#msg54663 date=1643803584]
Hello cavagnaro,
Thanks in advance
Ok so IXN does have correctly mapped the Queue, we can discard a CfgServer issue.
As Kubig mentions, then we go back to WDE, can you please share the full fb options you have configured?
Also a WDE startup log would be great
Offline Amr
Hello Dears,
Sorry for latency I've been busy with a long of tasks
so i will share Facebook configurations on WDE here below:
[b]facebook.auto-answer=true
facebook.defaul-queue=Facebook Inbound Queue
facebookprivatemessage.default-queue=Facebook Outbound Queue
facebookprivatemessage.outbound-queue=Facebook Outbound Queue
facebooksession.auto-answer=false[/b]
[b]And Here Is All WDE Configuration Options[/b]
[url=https://drive.google.com/file/d/1BwyTxpwdrrw_JO1ciyXmr5XJPjkdQRx_/view?usp=sharing]https://drive.google.com/file/d/1BwyTxpwdrrw_JO1ciyXmr5XJPjkdQRx_/view?usp=sharing[/url]
[b]And Also WDE Startup log with one interaction id = 045G6Q31YAADA00H[/b]
[url=https://drive.google.com/file/d/17VdscQ18x0OlIySqFJCQ_PsyE2HG4Kx0/view?usp=sharing]https://drive.google.com/file/d/17VdscQ18x0OlIySqFJCQ_PsyE2HG4Kx0/view?usp=sharing[/url]
Thanks for interest
Marked as best answer by Amr on February 07, 2022, 11:40:00 PM
There is a type in FB WDE option "facebook.defaul-queue" - try to fix the name to the right value "facebook.default-queue"
