" /> Statserver filters - Genesys CTI User Forum
Author Topic: Statserver filters  (Read 1224 times)
Offline PFCCWA
Statserver filters
« on: March 18, 2022, 12:18:44 AM »
hello,
i am trying to figure out if it is possible to create a filter to capture any value when applied to a statistic.
For example, i want to apply the statistic to a count of inbound calls, but filter out against userdata (header='status', values=credit, balance, owing and so on).
I have tried to create this filter :
name=status
value=PairExists(“status”, “*”)
would this be the correct way to do it?
thanks,
Marked as best answer by PFCCWA on March 21, 2022, 10:30:30 PM
Offline catanirex
Re: Statserver filters
« Reply #1 on: March 18, 2022, 07:45:12 AM »
You have to also enable wildcard filters on statserver config:
[statserver]
filters-allow-wildcards-in-values=yes
[Filters]
nameOfFilter=PairExists("udataName","*")
« Reply #2 on: March 18, 2022, 01:52:13 PM »
[quote author=PFCCWA link=topic=12262.msg54717#msg54717 date=1647562724]
hello,
name=status
thanks,
Be careful with the quotes you are using, there are some similar to " but look like yours here, like in italic, those won't work.
