" /> Service startup for GAX (Other Genesys components etc.) in Linux CentOS 7 - Genesys CTI User Forum
Author Topic: Service startup for GAX (Other Genesys components etc.) in Linux CentOS 7  (Read 4559 times)
Offline Janis
FlexLM:
[code][Unit]
Description=Genesys Flex License Daemon
After=network-online.target nss-lookup.target
[Service]
Type=forking
User=genesys
Group=genesys
ExecStart=/opt/genesys/flexlm/lmgrd -c /opt/genesys/flexlm/license.dat -l /var/log/genesys/flexlm/lmgrd.log
Restart=always
RestartSec=30
StandardOutput=null
StandardError=null
[Install]
WantedBy=multi-user.target
[/code]
Offline Janis
[quote author=ryusuf link=topic=12290.msg54868#msg54868 date=1651995378]
Do you use /var/run/genesys directory to store all the genesys service files? If you can, please elaborate so we can use these practices. :)
No, in /var/run/genesys we are getting PID files - small files where process identification numbers of genesys daemons are stored. Systemd likes it.
For systemd unit files (services) I would choose /etc/systemd/system. (https://unix.stackexchange.com/questions/224992/where-do-i-put-my-systemd-unit-file)
To be honest, I'm not the greatest Linux expert. Not sure that everything I do is according to best practices. But it is is working ;)
Offline ryusuf
[quote author=Janis link=topic=12290.msg54876#msg54876 date=1652081936]
Thanks, understood.  :)
The practices shared by you all will help in building the solution in a better way.
Offline ryusuf
[quote author=Janis link=topic=12290.msg54875#msg54875 date=1652081012]
FlexLM:
[code][Unit]
[Service]
Type=forking
User=genesys
Group=genesys
Restart=always
RestartSec=30
StandardOutput=null
StandardError=null
[Install]
[/code]
Thanks, let me try this out.
What i have noticed is that, whenever i start FlexLM from the GAX, it is toggling between STARTED/STOPPED. When i check the processes running for lmgrd, i could see a lot is getting created.
Does it have something to do with autostart configured in the options of FlexLM application object? is there anything additional that needs to be configured in the application object? Or we do not need to control it from autostart option in GAX?
Offline Janis
Never had an application object for FlexLM. Just a systemd unit file. Not sure if we can use Management Layer for any third party executable we have.
Offline ryusuf
[quote author=Janis link=topic=12290.msg54879#msg54879 date=1652088165]
Yes we can use Management Layer for third party executable like tomcat, cassandra, flexlm etc.
We have to create an application object of type Third Party Server and fill the command line, arguments and working directory. Under the options, we need to have a section start_stop with the option start_command and stop_command. (In case of Windows Flexlm, i had a start_command with value pointing to flexlm_start.bat file)
Inside the flexlm_start.bat file, i had the following command [b]net start "Flexlm Service" [/b](where Flexlm Service is the name of the Windows Service for Flexlm)
I have done that when using Flexlm in Windows servers.
But don't know, how it works in Linux  :)
