" /> Zabbix & Genesys call list - Genesys CTI User Forum
Author Topic: Zabbix & Genesys call list  (Read 1632 times)
Offline Engenesys
« on: May 08, 2022, 11:30:43 AM »
Greetings.
I want to use zabbix to track the call result in the collist, is this possible? For example, if the number of records with General Error is higher than the norm, then send a notification?
Re: Zabbix & Genesys call list
« Reply #1 on: May 08, 2022, 02:25:37 PM »
Maybe better ask Zabbix people on that one.
« Reply #2 on: May 09, 2022, 09:42:20 AM »
I would say it should be possible using Zabbix's Database (ODBC) monitor as it allows you to run SQL query against any (supported) database.
Offline Engenesys
« Reply #3 on: May 16, 2022, 05:52:18 PM »
[quote author=René link=topic=12297.msg54881#msg54881 date=1652089340]
I'll give it a try and let you know the results. thank you.
