" /> Softphone disconnects from Tserver - Genesys CTI User Forum
Author Topic: Softphone disconnects from Tserver  (Read 2703 times)
Vivek
I've a problem, our softphone closes the connection with telephone tserver automatically, tserver log file shows only the following:
@12:47:43.2318 [4524] Client TServer65 disconnected on 71, id=10b2:001c
g3_dn_unreg_hook(7013)
Here agent extension 7013 did not close the Softphone at all.
Anyone experienced this? pls advice me if you came across this. thanks.
Marked as best answer by on September 24, 2025, 11:45:52 PM
  • Undo Best Answer
  • Vivek,
    sorry for not looking at it earlier. I was in Thailand getting some sun.
    Regarding yoru question, there are several reasons why softphoen would disconnect from TServer and the most obvious one would be bad network. I know that it is impossible in most cases, but check it.
    Also, can you please dump the log from right before and after it? You should have commands like RequestRegisterAddress, etc in TServer log as well. I have noticed from log that you are using G3. Well, depending on how you register your DN type, your client would be kicked off by TServer.
