" /> How to disable PlayApplication block in workflow changing original DNIS? - Genesys CTI User Forum
Author Topic: How to disable PlayApplication block in workflow changing original DNIS?  (Read 1417 times)
Offline kevinwang
Hi, guys,
I have a URS centric  workflow/callflow development.
In workflow,  I use playApplication  block to call IVR callflow.  I created  a voip over ip service DN in sipswitch,  MSML_Service.
then I noticed DNIS is changed to MSML_Service  from my original RP,  where my workflow is loaded.
But I need this original DNIS  in my workflow.
How to disable this DNIS replacement by MSML_Service?
thx.
Kevin
« Last Edit: June 24, 2022, 04:48:45 AM by kevinwang »
Offline Marreco
Hi Kevin,
I believe you can create a user data in the dnis workflow (thisdn) for input in the vxml.
I recommend, based on the business rule of your flow, to perform the deleteudata if the interaction returns to the beginning of the flow with another DNIS.
This is a suggestion. I already had this scenario where I could solve just this way.
Att,
