" /> Force trunk and CPN in a TRoute using SipServer 8.1 - Genesys CTI User Forum
Author Topic: Force trunk and CPN in a TRoute using SipServer 8.1  (Read 1323 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: February 15, 2023, 12:36:51 PM »
Hello everyone, hope everything's fine around there. Currently our outgoing calls pass through 2 sip trunks configured with a set CPN that overrides the ANI when routing calls to external parties; there's a way to force a troute to use a specific trunk as a parameter without changing the dialplan? and how to configure the trunk to pass the ANI as the CPN?
Best regards,
Gef.
Offline hsujdik
Re: Force trunk and CPN in a TRoute using SipServer 8.1
« Reply #1 on: February 15, 2023, 01:19:54 PM »
you could use geo-location (see chapter 5 of SIP Server deployment guide, item "Working with Multiple Devices")
Before setting the TRoute, set the AttributeExtensions (UpdateExtensions function of IRD) of geo-location. If using GVP, be sure to set reject-on-geo-location-nomatch on Resource Manager as false.
Offline Gef Buneri
« Reply #2 on: February 15, 2023, 02:22:38 PM »
Thank you HSU, no GVP here; I'll check that chapter.
« Reply #3 on: February 19, 2023, 12:26:49 AM »
geo-location could be configured on Trunk object as well. CPN should be also configurable via extension data - try to check current SIP doc to get required set of the options
