" /> Pulse9, ERROR on startup "Configuration of pulse plugin is invalid. Stop init" - Genesys CTI User Forum
Author Topic: Pulse9, ERROR on startup "Configuration of pulse plugin is invalid. Stop init"  (Read 1038 times)
Offline steven33068
Hello, I have  a new instance of pulse9 installed on a brand new host. Pulse attempts to load then we see "Configuration of pulse plugin is invalid. Stop initialization" The application appears to connect to the DB via its JDBC DAP however we see ZERO connections to the DB, the WBRT_APPLICATION table is never updated to reflect the pulse application object IDs. Collector cannot find the application ID so everything is stuck.
10:15:13.081 Std 09900 Configuration of pulse plugin is invalid. Stop initialization
10:15:13.081 Dbg 09900 Completing transaction for [com.genesyslab.gax.wbrt.service.InitializationService.init]
10:15:13.081 Dbg 09900 Initiating transaction commit
10:15:13.081 Dbg 09900 Committing JDBC transaction on Connection [jdbc:sqlserver://x.x.x.x:62114;connectRetryInterval=10;connectRetryCount=1;maxResultBuffer=-1;sendTemporalDataTypesAsStringForBulkCopy=true;delayLoadingLobs=true;useFmtOnly=false;useBulkCopyForBatchInsert=false;cancelQueryTimeout=-1;sslProtocol=TLS;jaasConfigurationName=SQLJDBCDriver;statementPoolingCacheSize=0;serverPreparedStatementDiscardThreshold=10;enablePrepareOnFirstPreparedStatementCall=false;fips=false;socketTimeout=0;authentication=NotSpecified;authenticationScheme=nativeAuthentication;xopenStates=false;sendTimeAsDatetime=true;replication=false;trustStoreType=JKS;trustServerCertificate=false;TransparentNetworkIPResolution=true;serverNameAsACE=false;sendStringParametersAsUnicode=true;selectMethod=direct;responseBuffering=adaptive;queryTimeout=-1;packetSize=8000;multiSubnetFailover=false;loginTimeout=15;lockTimeout=-1;lastUpdateCount=true;encrypt=false;disableStatementPooling=true;databaseName=Pulse9_Dev_db;columnEncryptionSetting=Disabled;applicationName=Microsoft JDBC Driver for SQL Server;applicationIntent=readwrite;, UserName=xxx_Admin, Microsoft JDBC Driver 9.4 for SQL Server]
10:15:13.097 Dbg 09900 Releasing JDBC Connection [jdbc:sqlserver://xxxx:62114;connectRetryInterval=10;connectRetryCount=1;maxResultBuffer=-1;sendTemporalDataTypesAsStringForBulkCopy=true;delayLoadingLobs=true;useFmtOnly=false;useBulkCopyForBatchInsert=false;cancelQueryTimeout=-1;sslProtocol=TLS;jaasConfigurationName=SQLJDBCDriver;statementPoolingCacheSize=0;serverPreparedStatementDiscardThreshold=10;enablePrepareOnFirstPreparedStatementCall=false;fips=false;socketTimeout=0;authentication=NotSpecified;authenticationScheme=nativeAuthentication;xopenStates=false;sendTimeAsDatetime=true;replication=false;trustStoreType=JKS;trustServerCertificate=false;TransparentNetworkIPResolution=true;serverNameAsACE=false;sendStringParametersAsUnicode=true;selectMethod=direct;responseBuffering=adaptive;queryTimeout=-1;packetSize=8000;multiSubnetFailover=false;loginTimeout=15;lockTimeout=-1;lastUpdateCount=true;encrypt=false;disableStatementPooling=true;databaseName=Pulse9_Dev_db;columnEncryptionSetting=Disabled;applicationName=Microsoft JDBC Driver for SQL Server;applicationIntent=readwrite;, UserName=xxx_Admin, Microsoft JDBC Driver 9.4 for SQL Server] after transaction
