" /> Send outgoing calls from a strategy to a remote Asterisk - Genesys CTI User Forum
Author Topic: Send outgoing calls from a strategy to a remote Asterisk  (Read 1148 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: September 19, 2023, 12:45:01 PM »
Hi all, how should I proceed to route calls from a strategy to an Asterisk managed site located outside the company? I have the dest IP:PORT pair of the landing Asterisk and the tunneling to it is up&running, configured a SIP trunk too, pointing to that destination, but how I should route calls directly there? SIPServer 8.1.1, URS 8.1.4
I mean, in a regular scenario I would use a TRoute pointing to a specific number outside the org, but I'm thinking if having a remote geographic number is mandatory, or if it can be done directly to the IP.
Best,
Gef
« Last Edit: September 19, 2023, 12:52:58 PM by Gef Buneri »
Re: Send outgoing calls from a strategy to a remote Asterisk
« Reply #1 on: September 19, 2023, 04:31:56 PM »
Create a trunk, assign a prefix, define the IP port destination
In your strategy call that prefix and the destination number.
Of course as any other pbx integration you need to plan the numbering plan and probably use replace-prefix in the trunk too.
Enviado de meu SM-S918B usando o Tapatalk
Offline Gef Buneri
« Reply #2 on: September 20, 2023, 08:05:30 AM »
Thanks Cav. So the method doesn't changes... a destination number is mandatory. I thought there might be a direct ip to ip method.
« Reply #3 on: September 20, 2023, 08:06:18 AM »
I don't understand what you mean by IP method... I mean how the sip server would know which numbers to send to which PBX?
Offline Gef Buneri
« Reply #4 on: September 20, 2023, 08:12:01 AM »
It was just an idea... like a specific routing function based on IP only or who knows, some kind of DN like an RP configured to route calls without using an explicit geo number. Assuming the devices are connected through an IP tunnel.
« Last Edit: September 20, 2023, 08:13:52 AM by Gef Buneri »
« Reply #5 on: September 20, 2023, 08:13:32 AM »
Still no idea what you mean hehe
But no. No way PBX would work like this without a numbering plan.
Offline Gef Buneri
« Reply #6 on: September 20, 2023, 08:15:24 AM »
You know, when I start brainstorming ;D ok then, thanks for your time  :)
