" /> Queue and agents info in the same widget using Web Pulse - Genesys CTI User Forum
Author Topic: Queue and agents info in the same widget using Web Pulse  (Read 1525 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: October 20, 2023, 08:57:52 AM »
Hello all,
can web pulse display the data of queues and agents at the same time in the same view?
GAS 9, GA 8.5
Best,
Gef
« Last Edit: October 20, 2023, 01:55:30 PM by Gef Buneri »
Re: Queue and agents info in the same widget using Web Pulse
« Reply #1 on: October 23, 2023, 10:46:59 PM »
View? no...as in CCPulse you create templates based on objects, otherwise there wouldn't be a way to maintain metrics among different objects.
Offline Gef Buneri
« Reply #2 on: October 24, 2023, 07:34:17 AM »
Thanks Cav, I thought so. I don't use the pulse web much so I preferred to look into it.
« Reply #3 on: October 24, 2023, 02:10:38 PM »
[quote author=Gef Buneri link=topic=12473.msg55444#msg55444 date=1697792272]
Hello all,
GAS 9, GA 8.5
Best,
Gef
Do you mean within one single widget or within wallboard/dashboard? In second case, definitely it is possible as it is fundamental function of Pulse UI.
Offline Gef Buneri
« Reply #4 on: October 24, 2023, 05:46:32 PM »
Hello Kub. Same widget. All fine for same view/dash.
