" /> Can we use the Java servlet instead of using the VXML Block in Genesys Composer? - Genesys CTI User Forum
Author Topic: Can we use the Java servlet instead of using the VXML Block in Genesys Composer?  (Read 1250 times)
Offline Arunkumar12345
To use the Dynamic menu in the application, we required the VXML block in the Genesys Composer project. However, I need it to be completed in a Java-specific format, like servlet, like IBM RAD and Avaya OD. Please Help this out quickly
And what is the question/problem? Composer project could be Java based..
I want to use java code directly without using jsp , in composer project
Still no question or issue described - would be great to explain your concerns or what's the pain..
