" /> License Manager question - Genesys CTI User Forum
Author Topic: License Manager question  (Read 3090 times)
Kimi
We are using license manager with Solaris 2.8 and I wrote a script to shutdown all Genesys processes before machine is shut off. Everything works fine except for lmgrd. It keeps on asking me to select yes or no on whether or not I want to shut it down. How do I get rid of it?
Dave
  • If you're using the lmdown command, include the q option:
    lmdown q
    This will eliminate the "Are you sure?" prompt.
    The rest of the options are outlined in the FLEXlm end user manual (enduser.pdf) located in the installation folder for license manager.
