" /> 'periodic threshold' on CCPulse+ - Genesys CTI User Forum
Author Topic: 'periodic threshold' on CCPulse+  (Read 4650 times)
vayssac
I want to know if someone try to create some periodic threshold (each
4 seconds for example) to send some statistics (with an appropriate
action) outside the CCPulse+ (mail, file, ...). For example write
these statistics on a log file, ...
I try to do it with 2 different thresholds on the same statistics, to
make sure that the 'true' and the 'false' result will be on
differents threshold. For example for each update (number of
CallWaiting in a VQ) I can write this stat on a log file. All this
stuff works fine. But...
I'm looking for the same think but using the computer time, or
something like that...
Best regards.
My knowledge on Genesys environement : passed CGE and CGRP 6.5
Contact Center Solution Architect.
Philippe Vayssac.
Offline Marpos
Re: 'periodic threshold' on CCPulse+
« Reply #1 on: February 26, 2016, 02:39:02 PM »
  • Hi, anyone have an idea of this ?. I need exactly the same as him.
    « Reply #2 on: February 29, 2016, 08:53:36 AM »
  • I think it is better to achieve that through developing some "easy" app in PSDK.
    Offline Marpos
    « Reply #3 on: February 29, 2016, 12:37:50 PM »
  • CCPulse got a built in SDK beside tresholds and actions ?
