" /> Avaya Vs Genesys - Genesys CTI User Forum
Author Topic: Avaya Vs Genesys  (Read 29980 times)
ranvir
Avaya Vs Genesys
Can anyone give me a comparison of Avaya Vs Genesys. Thanks!!
lou_surfer
Avaya Vs Genesys
  • Avaya
    Skills Based routing more like ACD queues
    Can load balance mulitsites with BSR
    Continual polling with Enhanced look ahead feature.
    Genesys
    Skills based routing
    Virtual Queue
    Real Time load balancing
    Multisite/Switches types
    Lakshmikanth
    Avaya Vs Genesys
  • This might help you. It may not give the level of details you are looking at but provides overall details about it.
    http://mediaproducts.gartner.com/re...aya/123802.html
    Avaya Vs Genesys
  • Here is my take on Avaya Vs. Genesys.
    I feel like Genesys is an enhanced layer that wraps around Avaya. Many if not all of the functions in Avaya can be replicated in Genesys, but the truth of the matter is, you usually have Genesys crash and not Avaya.
    When comparing report data, for example, Genesys stats are ALWAYS compared to Avaya and if there is a discrepancy, it is Genesys stats that are being questioned and not Avaya's.
    Working with many Genesys product, I like the overall idea and most of the products because of the features. But FEATURE is defined in Websters as:
    " a prominent part or characteristic b : any of the properties (as voice or gender) that are characteristic of a grammatical element (as a phoneme or morpheme); especially : one that is distinctive"
    so, you have something that feature is a part of, and this, unfortunately for Genesys, is still PBX. As long as Genesys relies on PBX, it will only be that: a nice and expensive feature.
    Perhaps this explains Genesys' move into IPPBX...
    So, summarize it:
    Genesys is to Avaya what Advanced Settings in your Windows Network Settings are to Windows itself.
    Malla
    Avaya Vs Genesys
  • He is looking for a comparision on AIC vs Gensys, for that matter all the cti solutions depends upon epbx, genesys is more open to other epbx when compare to AIC, Genesys is More versitile cti product, it is the best when comparision to other CTI products
    Gensys is an alcatel company, Alcatel as its own pbx
    SuperGlide
    Avaya Vs Genesys
  • Hiya....We did the Genesys vs. Avaya analysis a couple of years back and "at that time" decided upon Genesys. The resoning behind this is that the Avaya AIC product was still in early release and essentially vaporware, but we certainly liked the look of it.
    In the end the decision for you should be driven by the Business requirements that are behind the project as neither solution is cheap. What exactly do the Business want to achieve and for how many agents and what functions do they want (inbound/outbound/IVR etc)
    Cheers
    Avaya Vs Genesys
  • Wow...I did not figure that...Everyone is talking about AIC, even though I did not see it in his post. In fact, the scary thing is I do not even know what AIC stands for: Avaya Interaction Center, would be my initial guess.
    Time to google!
    SuperGlide
    Avaya Vs Genesys
  • A very good guess mate!!!!! I like the reporting system that comes with it.
    Mursid
    Avaya Vs Genesys
  • Do you have the comparison of intelligent routing between avaya and genesys.
    Mursid
    Jairo Angulo
    Avaya Vs Genesys
    « Reply #9 on: January 01, 1970, 12:00:00 AM »
  • Please send my comparation betwen CTI Avaya vs CTI Genesys
    Rene
    Avaya Vs Genesys
    « Reply #10 on: January 01, 1970, 12:00:00 AM »
  • Is there anybody that has done a recent comparision of Genesys v7.x vs Avaya Aic latest release (6)
    Stonecold
    Avaya Vs Genesys
    « Reply #11 on: January 01, 1970, 12:00:00 AM »
  • I`m also looking for a comparison between Avaya AIC and Genesys.
    Are there any new`s.
