" /> SCI won't start - Genesys CTI User Forum
Author Topic: SCI won't start  (Read 3492 times)
newbie
SCI won't start
Has somebody experienced the following problem?
SCI starts and presents Login Dialog. When the right username and password is entered then the main SCI screen should appear, but that never happens.
No SCI proccess can be found on taskmanager. Application just dissapear. I am talking about SCI 7.0 on Windows XP SP2
Any help would be appreciated.
Short
SCI won't start
Yes...
The problem is that SCI version 7.1.000.05.b3 does not include configuration wizard components...
7.1.000.05.b4 works fine!
Solution 1: Install the configuration wizard from the Management Framework CD on the machine where SCI wont start.
Solution 2: Install an older version of SCI or build 4 of SCI (IP_SCInterface_7100005b4_ENU_windows.zip).
Marked as best answer by on Today at 08:35:43 AM
SCI won't start
  • Undo Best Answer
  • I can confirm this problem. Please install an earlier version.
