" /> GENESYS implementation issues - Genesys CTI User Forum
Author Topic: GENESYS implementation issues  (Read 4150 times)
Sunil
HI,
I am involved in developing a call center where we are using GENESYS Tserver along with siemens switch, rockwell ACD and periphonics IVR.
I need help regarding the exact role of a system integrator in this and what the issue to be kept in mind which approaching an integration of this sort. I wish to know what components are supplied by the vendor and what is required from an integrator. Also If I get pointers to some resources regarding the same on the web, it wud be very helpful.
I know the question is an open ended and broad one but kindly help with whatever information u have.
Regards
Sunil
Kath
  • Hello, Sunil,
    you have a very very broad question. And I think it would be very difficult to answer it all. Usually, vendors provide you with hardware and software. The role of SI is to create a design, put it all together, testing it and support it. Vendors are there to provide you with support on such thing as fixing system bugs and possible suggestions on how you should proceed.
    Unless you have done it before, starting on this kind of project by yourself is very very dangerous. The fastest site turnover I have seen so far was one month; however, on avergae we are talking about a three monthes to a year commitment.
    Will you be subcontracting companies for each particular product, or will you attempt to do it all internally?
    The really important things you have to worry about are:
    will the vendor support your configuration
    how much commitment is there AFTER the project is finished. Who will support what and how.
    There are hundreds of consulting firms which specialize in developing procedures for call centers. If you have resources, use them.
    One very important thing Genesys will NOT deal with you unless you are AT LEAST CGEcertified. Keep that in mind. This is a very very very important thing to consider. When something goes wrong, and you will email Genesys support, they will require that the person be CGE certified, or else they would not even approve of your call center, thus they will issue any kind of technical support even if it is a product bug.
    If you have any specific questions about Genesys, fire away and I will try to help you as much as I can.
    Cheers,
    Kath
