" /> CPD dial plan - Genesys CTI User Forum
Author Topic: CPD dial plan  (Read 4660 times)
Tawfik
CPD dial plan
We have multiple CPDs used to initiate calls at different sites. the sites are in cities A and B. If we have a contact number with an NPA of City A, then if the call is to be dialed from city B, then we do not need to have a 1 before. But if the call is dialed from the B location the number dialed will have to begin with 1. I looked through the documentation and i can't see where we can make use of dialing plans when using the CPDs ? Any idea ?
Marked as best answer by on Yesterday at 05:17:36 PM
Tony Tillyer
CPD dial plan
  • Undo Best Answer
  • Off the top of my head; in the OCS settings, there is a setting for Dialling Rules a bit like the "Dialing Location" settings you might find in Windoze.
    I think...
    Tony
    Tawfik
    CPD dial plan
    thanks, but the only dialing X that i can see is the dialing mode of the campaign... We are using 7.0
    LeszekM
    CPD dial plan
    There is the option "public_network_access_code". It should be set on the switch level in the switch properties that is in the Annex tab in the section named Default .
    It should be set to the empty string in A and to 1 (the prefix) in B.
    I hope that helps.
    Leszek
    Tawfik
    CPD dial plan
    Thanks for the info. Ungortunately, this is not fixing the problem we have. The thing is that a phone number may be toll for one location and not the other meaning that we may or may not need to prefix the number with 1 depending on where the call will be dialed from. I am pursuing investigations on how to do that with an M1 pbx since Genesys seems not doing it .....
    Syl
    CPD dial plan
    You are right, you are better off using your Meridian1 ESN Dialing Plan with FCAS (Free Calling Area Screening) to manage the calls.
