" /> Genesys T server refusing certain connections - Genesys CTI User Forum
Author Topic: Genesys T server refusing certain connections  (Read 4294 times)
cb
« on: August 11, 2006, 12:31:08 PM »
Hi Guys, I have a problem. Genesys T server is refusing certain connections. We connect via our CRM solution and connect in with the extension. The error we receive is "Warning: Registration dc attempt 3 of 10 failed on DN 12950 - next attempt will be made in 1910 msec"  This as I understand is indicating congestion between the switch. It is only affecting certain extensions. We currently use a lucent solution.
Any ideas...I am fairly new to genesys.
Offline Fra
Re: Genesys T server refusing certain connections
« Reply #1 on: August 11, 2006, 01:57:42 PM »
  • Cb,
    your problem could be related to many different things; anyway:
    [list]
    [li]are those extensions you try to register to defined in CME?[/li]
    [li]what is the TServer option disable_digits_collection  set to?[/li]
    [li]what is the value of the TServer option max-registration-per-sec?[/li]
    [/list]
    IanDS
    « Reply #2 on: August 12, 2006, 09:20:35 AM »
  • you might also want to check that the extn exists in the switch or is an extn type and not some other weird config.
    plz109
    « Reply #3 on: August 13, 2006, 12:36:29 PM »
  • [quote author=cb link=topic=1782.msg5688#msg5688 date=1155299468]
    My initial guess would be that that DN does not exist in your PBX or is not CTI-enabled. Check your PBX DN configuration.
