" /> Wallboards - Genesys CTI User Forum
Author Topic: Wallboards  (Read 20834 times)
Offline sy278
Wallboards
« on: August 16, 2006, 01:27:49 PM »
Hi guys,
at the moment my company is using ccPulse on Plasma Screens as wallboards, however, they are a mess and are causing no end of problems.
I am thinking of trying to create a webbased version of the display so that we can fully customise it (not to mention use much less processor power)
I have seen that you can access the stats via the ActiveX toolkit, but I have no ide how to do acess them, can anyone point me in the right direction??
tony
Re: Wallboards
« Reply #1 on: August 16, 2006, 01:45:43 PM »
The Genesys Interface Server (GIS) is the norm for thin-client based solutions for Real-Time Reporting, which would work with java or ActiveX.
Tony
Offline sy278
Re: Wallboards
« Reply #2 on: August 16, 2006, 01:50:17 PM »
Yeah but my company has refused to pay the £30k they were asked for it  >:(
Offline Genecist
    • Screen Pop Software
Re: Wallboards
« Reply #3 on: August 16, 2006, 02:07:58 PM »
[quote author=Tony Tillyer link=topic=1790.msg5744#msg5744 date=1155735943]
Tony
[i]which would work with java or ActiveX[/i]
GIS also works very well using .Net SOAP clients.
Offline Genecist
Re: Wallboards
« Reply #4 on: August 16, 2006, 02:13:26 PM »
[quote author=sy278 link=topic=1790.msg5746#msg5746 date=1155736217]
Amazing, the costs involved with Genesys.
Nevertheless, I would suggest using GIS.  As discussed on another thread, you can do all sorts of things like hitting the stats db directly and retrieving your stats...but this probably won't be supported by Genesis.  And if you do an upgrade to a newer version, there's nothing to stop them from changing the database schema, which would then result in you having to retool your applications...which could very well be more expensive than just buying the GIS license.
Also, depending on which stats you need...you can retrieve some info from TServer directly, like the number of available agents in a queue, number of calls waiting in a queue, etc.
This was discussed in this thread:
http://www.sggu.com/smf/index.php/topic,1756.0.html
Offline sy278
Re: Wallboards
« Reply #5 on: August 16, 2006, 02:18:45 PM »
thanks,
I'll look into it, though I have a feeling it wont work as all our Queues ar VQ's
tony
Re: Wallboards
« Reply #6 on: August 16, 2006, 02:32:40 PM »
All of our deliveries go through VQ's but that never stopped us developing a thin client for Agents.  Ahem - NOT FOR RESALE...
Tony
Offline sy278
Re: Wallboards
« Reply #7 on: August 16, 2006, 02:36:22 PM »
[quote author=Tony Tillyer link=topic=1790.msg5750#msg5750 date=1155738760]NOT FOR RESALE...[/quote]
But you could give it away!  ;)
tony
Re: Wallboards
« Reply #8 on: August 16, 2006, 02:42:37 PM »
S'not mine and I don't have the source code...  :-[
Offline sy278
Re: Wallboards
« Reply #9 on: August 16, 2006, 02:44:19 PM »
lol thanks anyway
Online René
Re: Wallboards
« Reply #10 on: August 16, 2006, 03:16:43 PM »
I'm pretty sure Genesys sells a special license for GIS named "Wallboard connector" where the price is less then 5k euro. That licences allows just one connection to GIS but doesn't limit number and types of collected statistics.
I would really suggest you to use GIS because the other ways are usually more expensive at the end... especially when you take into account the cost of support and maintenance. That's my experience.
René
Offline sy278
Re: Wallboards
« Reply #11 on: August 16, 2006, 03:37:45 PM »
[quote author=René link=topic=1790.msg5755#msg5755 date=1155741403]
René
Agreed
Unfortunately my company wont budge on it.
tony
Re: Wallboards
« Reply #12 on: August 16, 2006, 08:28:23 PM »
Try this; Remind the business that you would need to develop a solution "in house" and you would still need the (Internal FTE) development costs.  Use GIS in the first instance and your (Internal FTE) development costs are greatly reduced.  Either way you'd have to pay if your business needs something other than CCPulse(+).  Without [i]some[/i] development costs, it just can't be done.
Or
Get them to get you on a course and do it yourself - you win, they win (since it comes out of the training budget and not their coffers).
Or
Re-deploy CCPulse Views with the stats they need now, rather than what is on the screen today.
- Try writing up a paper showing their (3) options (with costs) and break it down in nice, easy chunks for them to understand!  ;)
Tony
[quote author=sy278 link=topic=1790.msg5756#msg5756 date=1155742665]
René
Agreed
Offline sy278
Re: Wallboards
« Reply #13 on: August 17, 2006, 07:40:58 AM »
Yeah ill try that, thanks.
The main problem we have with the cc Pusle view is that it is so untidy, to get it to display meaningful titles for the fields were having to use Excel and Notepad, so it just looks really messy.
So we have titles like ECC in Excel that ccPulse shows as VQG_CAT_CSS_ECC_SL, we thought the alias field for the VQs in Config Manager would have helped but it doesnt.  :(
tony
Re: Wallboards
« Reply #14 on: August 17, 2006, 09:16:55 AM »
Aha - 2 points then;
In any version of CCPulse, you can specifiy how the Agent Names are being displayed in a View\Template.  In the main, you change the Forename, Surname and Initials around in a format you require, using the following as a guide;
%n = Employee ID
%F = First Name
%f = First Name Initial
%L = Last Name
%l = Last Name Initial
You should be able to find them around about here, in your Registry;
...\HKEY_CURRENT_USER\Software\GCTI\CallCentre\CUSTOM DEFINITION\FormatAgentInfo
ALSO:
[b]After [/b] version 6.5.001.05, you get Alias names (in your case, the VQ Alias names) by default, when you create new Views
That's gotta help... right?  ???
Tony
