" /> Genesys installation: HowTo? - Genesys CTI User Forum
Author Topic: Genesys installation: HowTo?  (Read 8828 times)
fibonacci23
« on: September 25, 2006, 10:05:21 PM »
Hi all,
i'm a newbie in genesys affairs and i need some help in installation of genesys 7.2 on windows 2003 server.
what is the order of installation? What have i to install first, second ... last?
thanks in advance!
Fibo
Re: Genesys installation: HowTo?
« Reply #1 on: September 26, 2006, 05:52:40 AM »
Hi, Fibo,
looks at deployment guide for Genesys framework. It tells you every step of how to do it.
If you really just want to get the thing running, you have to install configuration layer and then you can let the wizard do the rest.
The best way to get rolling:
1. read configuration layer deployment
2. read management layer
3. get access to DB and create a database you want Genesys to use
4. install wizard (it is on your CD)
5. just run through the step there
Of course, you need to know what you are doing, and if it is your first time, I think you will end up with something strange.
The best bet would be to identify:
1. do I have PBX or simulator? And if so, what do I use?
2. do I use Windows or Solaris?
3. Do I want to install only framework or more?
Deployment guide allows you to enter all that information in to help you go through the hoops.
If you want, I can put together a simple instructions for you, but you need to tell me 1,2,3
fibo
« Reply #2 on: September 26, 2006, 12:31:44 PM »
Hi Victor,
thx a lot for your quick reply!
It would be very nice, if you could put together a simple instructions for me..
1. First, I want to make a test-installation without a pbx. Later I have to install genesys with Avaya Communication Manager.
2. First, I use windows xp and windows 2003 server. Later, I want to install it on solaris 10.
3. First, I only want to install the framework with its most important components..
thx!
Fibo
tony
« Reply #3 on: September 27, 2006, 12:24:29 PM »
:o
...Good luck with that...
« Reply #4 on: September 28, 2006, 03:16:31 AM »
Ok, give me a few days. :) I will try my best.
« Reply #5 on: September 29, 2006, 05:12:27 AM »
Genesys Express for Solaris?  ;D
Does it exists?
fibonacci23
« Reply #6 on: September 29, 2006, 08:47:42 AM »
Thank you Tony, thank you Vic!
Offline Adam G.
  • Still Gorgeous.......
« Reply #7 on: September 29, 2006, 09:11:23 AM »
Hi Guys,
Why doesn't one of you put what you have on the Wiki (www.thegenwiki.com) and then everyone can add to it?
I wouldn't be surprised if a rather good document was produced in next to no time at all?
Koki
« Reply #8 on: September 29, 2006, 09:53:32 AM »
This is an excellent idea!
I would love to have something like this!  ::)
How do I join? ???
Marked as best answer by on Today at 08:30:32 PM
Offline Adam G.
« Reply #9 on: September 29, 2006, 10:31:15 AM »
  • Undo Best Answer
  • [quote author=Koki link=topic=1841.msg6020#msg6020 date=1159523612]
    How do I join? ???
    You could go to www.thegenwiki.com and click on the "Log in / create account" link in the top right corner of the page, create a username and then you'll have edit permissions....
    Easy really  :)
    « Reply #10 on: October 05, 2006, 03:04:02 AM »
    After several sleepless nights and many days of not doing my work, here it is! Announcing the long-awaited "how to install Genesys andd live to tell about it" installation manual.  It is not pretty, but it works and that is all that matters. I will add URS and StatServer soon.
    In the meantime, try it, and if you cannot get it to work, just ask :)
    Good luck!
    fibonacci23
    « Reply #11 on: October 05, 2006, 12:37:39 PM »
    hey vic, your're GREAT, man! Thank you very much that you took the trouble.
    i will pass through your instructions within the next days..
    best regards,
    fibo
