" /> ICS and Oracle 9i - Genesys CTI User Forum
Author Topic: ICS and Oracle 9i  (Read 5338 times)
vivek1
ICS and Oracle 9i
« on: December 12, 2006, 12:58:51 AM »
Currently I am using ICS and oracle 8i. In oracle 8i I was able to use internal id to create mst_intercache table and few procedures. In 9i internal id is not available. Does anyone know what id should I use in 9i instead of "internal" id?
I can use sys id instead of internal id. but sys id can be used as sysdba in 9i. that is why I am not able use sys id.
pls help me.
Thanks in advance.
Re: ICS and Oracle 9i
« Reply #1 on: December 12, 2006, 08:54:14 AM »
  • Hi,
    Oracle 9.0 and 9.2 is officially supported by Genesys starting ICS 6.5.1 so you should be able to create mst_intercache table using SQL script provided with MS-TServer. Do you have troubles with that script?
    René
    vivek1
    « Reply #2 on: December 12, 2006, 02:19:23 PM »
  • my question is, what oracle id I should use to login before run the script?
    Thanks.
    « Reply #3 on: December 12, 2006, 09:17:48 PM »
  • You should create a new user and use that one to log in and create mst_intercache table. Later you have to use that user to allow ms_tserver access to mst_intercache table (connection parameters specified via DAP in Genesys Configuration).
    René
    vivek1
    « Reply #4 on: December 13, 2006, 02:34:57 AM »
  • i created new user and ran mstserver and received below error.. any idea how to fix the error?
    2/12/06 21:25:53.532  Trace  nes0ap02  MSTServer651  GCTI-00-04541  Message EndObjectsList received from  724 ( CfgServer  )
    @21:25:53.5320 [4541] EndObjectsList received from 724 (CfgServer) RedID=32
    12/12/06 21:25:54.828  Standard  nes0ap02  MSTServer651  GCTI-01-51018  ICache DB error 'ORA-01031: insufficient privileges
    ORA-06512: at "ICSUSER.MST_CHECK", line 225
    ORA-06512: at line 2
    *mstERROR*: 21:25:54.8280 ICache DB error 'ORA-01031: insufficient privileges
    *mstERROR*: 21:25:54.8280 Error Response: ExId=00001 DbRq=00005 T=2 R=0 W=1
    Command: mst_Check ver=5, Rc=@out
    12/12/06 21:25:54.844  Standard  nes0ap02  MSTServer651  GCTI-01-51017  ICache error 'Database failed' during 'error operation'. Action = Stop & Shutdown.
    « Reply #5 on: December 13, 2006, 08:31:06 AM »
  • Vivek,
    Your issue is caused by insufficient privileges granted to user "ISCUSER". I found a solved ticket mentioning following permissions have to be granted:
      Create Any Table
      Create Procedure
      Select Any Table
    Could you check current permissions assigned to ICSUSER and try again with permissions above?
    René
    vivek1
    « Reply #6 on: December 13, 2006, 05:11:01 PM »
  • Thanks Rene.
    Last night I was able to make it work as you suggested.
    Thanks!!
