" /> Manage Options - delete Annex - Genesys CTI User Forum
Author Topic: Manage Options - delete Annex  (Read 3648 times)
merlin
« on: December 14, 2006, 09:56:25 AM »
I've noticed that modify options of CME doesn't work. Somebody have solved this problem?
I have to delete the annex of some skills and exitension. All this object have the same Annex.
Thank you in advance,
Sandro
Offline mark
Re: Manage Options - delete Annex
« Reply #1 on: December 14, 2006, 12:32:39 PM »
  • Well spotted.
    Have just tried this in 7.2 and the same thing happens. It will not show the current annex items for any of the users selected.
    Mark
    merlin
    « Reply #2 on: December 14, 2006, 12:38:20 PM »
  • I found the solution.
    We made a mistake in the usage of the function.
    You have to go on the delete Annex, click on modify annex and create the section you want to delete. at this point confirm and execute. The section will be deleted!
    Bye,
    Sandro
