" /> ICON installation - Genesys CTI User Forum
Author Topic: ICON installation  (Read 3352 times)
Offline Fra
ICON installation
« on: January 18, 2007, 11:49:05 AM »
I'm trying to install ICON 7.2.000.18; in the ICON (outdated  >:( ) deployment guide to execute the provided scripts to initialize the IDB in the following order:
1. gcc_<db_type>_schema.sql
2. gos_<db_type>_schema.sql
3. gcc_<db_type>_dict.sql
4. gcc_<db_type>_stp_api.sql
5. gcc_<db_type>_stp_sys.sql
but I got "Std 25018 Fatal error: database queue [DBWCALLPARTY]: schema version [] is obsolete" followed by an ICON crash.
I have found in the release notes that starting from 7.2.000.14 version a new set of scripts is provided:
gcc_<db>_dict_2.sql
gcc_<db>_schema_2.sql
gcc_<db>_stp_api_2.sql
gcc_<db>_disp.sql
gcc_<db>_version.sql
A deployment procedure is said to be included in the software installation package, but actually there is not.
Since they are mentioned as "extensions", I run both old and new set, but I'm still having the same error above. Should only the new set be run against the db? Does anybody have the updated deployment procedure?
Offline LeszekM
Re: ICON installation
« Reply #1 on: January 18, 2007, 01:13:05 PM »
The sequence of the scripts to run is described in the deployment procedure which can be found in the ICON installation package.
The sequence is:
gcc_<db>_schema.sql          Main core schema script
gcc_<db>_dict.sql                Dictionary content
gos_<db>_schema.sql          Outbound schema script
gcc_<db>_stp_api.sql            Core stored procedures
gcc_<db>_stp_sys.sql            System stored procedures
gcc_<db>_dict_2.sql            Dictionary extension
gcc_<db>_schema_2.sql        Schema extension
gcc_<db>_stp_api_2.sql        Stored procedures extension
gcc_<db>_disp.sql                Dispatcher interface upgrade
gcc_<db>_version.sql            Schema version upgrade
Regards,
Leszek
Offline Fra
« Reply #2 on: January 18, 2007, 01:41:36 PM »
[quote author=LeszekM link=topic=2004.msg6776#msg6776 date=1169125985]
The sequence is:
Regards,
Leszek
Thanks a lot LeszekM,
now it works  :D I don't why I don't have any deployment procedure in my package  :-\
