" /> How to cancel Retrieve Record in OCS - Genesys CTI User Forum
Author Topic: How to cancel Retrieve Record in OCS  (Read 3249 times)
Outbound Reporting
« on: February 26, 2007, 07:48:31 AM »
Dear Cavagnaro, Rene and Vic,
thank-you very very very much for all your helpful comments. With your help I am almost finished with my project, but there is a small problem that I cannot resolve.
Can you please tell me how to cancel the update of the retrieved record?
I know there is PreviewRecordRequest but how do I cancel it?
[tt][color=orange][glow=red,2,300]Outbound Report Girl[/glow][/color][/tt]
Re: How to cancel Retrieve Record in OCS
« Reply #1 on: February 26, 2007, 08:56:35 AM »
I'm not sure I do understand well what you want to achieve...
  If you want to mark a record as "Cancelled" (= do not dial, do not re-sent another agent) then use RequestRecordCancel.
  If you want to reject a record (= agent doesn't want to call the record at this time) then use RejectRecord.
Marked as best answer by on July 22, 2025, 04:08:32 PM
« Reply #2 on: February 26, 2007, 11:52:47 AM »
  • Undo Best Answer
  • Here we go:
    [color=green][size=8pt]Dim gRecordHandle As Integer
    Dim gCallingList As String
    Dim gEventInfo As New TEventInfo
    Dim gList As New CTKVList
    Dim gApplicationID As Integer
    Dim gCampaignName As String
    Private Sub btnUpdateCancel_Click()
    Call AddAttachData("GSW_AGENT_REQ_TYPE", "RecordReject", , True)
    Call AddAttachData("GSW_APPLICATION_ID", "", gApplicationID)
    Call AddAttachData("GSW_CAMPAIGN_NAME", gCampaignName)
    Call AddAttachData("GSW_CALLING_LIST", gCallingList)
    Call AddAttachData("GSW_RECORD_HANDLE", "", gRecordHandle)
    Call SendRequestToOCS
    End Sub
    ' here is a function that makes it easy to pack attach data
    Private Sub AddAttachData(keyname As String, key_value_string As String, Optional key_value_int As Integer = -1, Optional init_data As Integer = False)
    Dim myPair As New CTKVPair
    Set myPair = New CTKVPair
    If init_data Then
        gEventInfo.UserData.Clear
        Set gEventInfo = Nothing
        Set gEventInfo = New TEventInfo
        Set gList = Nothing
        Set gList = New CTKVList
    End If
                myPair.Key = keyname
                If (key_value_int = -1) Then
                            myPair.Type = CTKVType.CKVTypeString
                            myPair.StringValue = key_value_string
                Else
                            myPair.Type = CTKVType.CKVTypeNum
                            myPair.NumValue = key_value_int
                End If
                gList.AddTail myPair
    End Sub
    'and here is a function to send request
    Private Sub SendRequestToOCS()
                gEventInfo.UserData = gList
                TExtension1.TSendUserEvent gEventInfo
    End Sub[/size]
    [/color]
    Is it what you wanted? I did not have much time to write code, so don't blame me if it is too ugly :>
