" /> Call Concentrator does not log to EVREFEX, EVDATA - Genesys CTI User Forum
Author Topic: Call Concentrator does not log to EVREFEX, EVDATA  (Read 3413 times)
scott
Hi, I have some problems with CCON. I set it up properly, I think. However, when I use the Starter Application from Genesys to make a call, answer the call and then send attached data, all using a PBX simulator, there is no data logged to EVREFEX and EVDATA; there is data in GCDR and SCDR. What could be th eproblem? I have checked the options already and EVENTDATA and EVREF are already truned on.
THnaks for the help
Jeff
  • Scott,
    you can either use EVREFEX or EVDATA. Make sure that evrefex option is on and that you have defined UserData parameter in CCon.
