" /> full export of ODS DB and Geneysys configuration DB - Genesys CTI User Forum
Author Topic: full export of ODS DB and Geneysys configuration DB  (Read 4387 times)
MaxonMan
« on: March 01, 2007, 04:48:08 PM »
Hello ,
In order to fix a Service Request, the Genesys Support asked me to full export of ODS DB and Geneysys configuration DB export.
Do i have to use the Configuration Import Wizard for the two exports ?
thank you for your help
Marked as best answer by on July 17, 2025, 01:31:22 PM
Re: full export of ODS DB and Geneysys configuration DB
« Reply #1 on: March 01, 2007, 06:00:38 PM »
  • Undo Best Answer
  • Hi MaxonMan,
    I don't think that Configuration Import Wizard is the best tool especially when it doesn't work for you. I suggest you exporting the databases using your DBMS tools (MSSQL2000 - Enterprise Manager, Oracle - exp command). Your DBA should know how to do it.
    MaxonMan
    « Reply #2 on: March 01, 2007, 06:36:14 PM »
    there is any Genesys utility to do that ?
    i can remember that CCW ( configuration conversion wizard ) can do such things.
    do you agree ?
    « Reply #3 on: March 01, 2007, 06:42:10 PM »
    Yes, you can use CCW for the export of Genesys Configuration but there is no such tool for ODS. The only way is to use DBMS tools.
