" /> How does URs handle multi-queue routing? - Genesys CTI User Forum
Author Topic: How does URs handle multi-queue routing?  (Read 23729 times)
URSMan
« on: July 17, 2007, 02:04:28 AM »
I would like to ask some help with answering the following question - how does URS decide which call to route to an agent when more than one queue is targeting it?
For example, I have three queues, A, B, C all targeting the same skill. There is one agent that has all these three skills and this is the only one agent current available. You have 100 calls in queue A, 5 calls in queue B, 1 call in queue C. How does URS handle the calls? Does it do it in a round-robin fashion, where it would send one call from A then one call from B and then one call from C?
I read somewhere that priority assigned to a call is local to a queue, therefore, if call A has priority 1000 in queue A and another call B has priority 1 in queue B, it does not mean that call A will always be routed before call B. Can you  please confirm that for me?
[move]URSMan rulez! ;D[/move]
Re: How does URs handle multi-queue routing?
« Reply #1 on: July 17, 2007, 06:30:00 AM »
Hello URSMan,
The interactions are routed based on their global priority which is set using the function "Priority". There is another function related to interaction's priority called SetVQPriority but that function sets priority of an interaction in connection to particular virtual queue (VQ) only.
I would suggest you to look at "Genesys Universal Routing 7.2 Deployment Guide". There is a chapter named "Business-Priority Routing" where you can find more information related to this topic.
René
PS. If you are on URS 6.5 then the global priority doesn't work as expected. It is fixed in release 7.x.
URSMan
« Reply #2 on: July 18, 2007, 12:25:46 AM »
Good afternoon, Rene, and thank-you for your reply!
What about calls that do not have Priority assigned to them? Does URS route them in a round-robin fashion?
Offline mark
« Reply #3 on: July 18, 2007, 07:30:06 AM »
Different skill levels and priority levels can cause calls to route differently to expected. Always worth running a set of tests just to confirm to yourself what is going on.
Then there is any service factor rules that may be in place that need to be considered.
Page 35 in the URS Deployment Guide (mentioned by René) has a small piece on Priority Tuning that would be worth a quick read, along with the Business Process Routing sections.
Mark
« Reply #4 on: July 18, 2007, 08:39:22 AM »
As I know every interaction has its priority set to default value 10 points at the beginning. But I don't know how URS handle these - I would bit it's kind of random selection. I definitely recommend you to read the Business Process Routing section as described functionality is targeted to solve your needs (multi VQs - one target).
René
« Reply #5 on: July 18, 2007, 10:17:05 AM »
I checked up on URSMan post, and you know, there is definitely something fishy about Priority routing with URS 7.1.xxx . I had two queues, both targeting the same agent, and I have added Increment[1] before queueing the call.
After waiting for a minute and then placing a call to a second queue, I would set agent to ready and you know, in some instances, URS would connect call #2 (priority=0) to operator even though there is call (priority=1) still in the other queue targeting the same agent.
tagret-order is set to random, so I wonder what this could be...
« Last Edit: July 18, 2007, 10:35:44 AM by victor »
Mike Kamlet
« Reply #6 on: July 18, 2007, 07:43:41 PM »
Other considerations:
1) Are you using multiple URS with LDS??
    If so there are other considerations related to reserve agent, pulse-time, etc -- we've run into issues with this in the past
2) With a single URS, priority should work fine -- highest priority always gets routed regardless of time in queue.  In fact if you have a call without priority set and a call with priority of 1, the call with priority 1 will always route first.
Mike
« Reply #7 on: July 19, 2007, 03:48:42 AM »
Good morning, Mike,
I checked again and again, and if you use SelectDN() and then Suspend() commands, I do get about 3 out 14 calls when priority 0 call is routed to an agent even though priority 1 call is still targeting the same agent with only one URS 7.1.xxxx and one statserver.
I will try to up the part of the log later on today or tomorrow.
Best regards,
« Reply #8 on: July 24, 2007, 04:03:39 AM »
To follow up on why URS is routing priority 0 when there is priority 1 call waiting in another queue, here is a sample log:
there is Skill_A and Skill_B and operator has both of these skills.
There are two strategies, targeting skill A and skill B respectively.
Strategy is setup so that call's priority is increased every minutes by one count.
Call A - 0092017974d65052 - was in queue A for over a minute for Skill A and has priority 1
Call B -  0092017974d65053 - was in queue B for less than a minute and has priority 0
Once agent becomes ready, call B is sent to operator before call A (despite call A having a higher priority). Once agent finishes call B, call A is then routed to the same operator.
Why is it doing such a nasty thing?
[code]
18:11:58.727_M_I_ [10:06] tenant Resources GroupAgents <VAG_Skill_A_H>: statistic ##content with server StatServer <request=7, status=2> asked
    _M_I_ [17:05] VQ(101b7ed20) target (name=VAG_Skill_A_H, location=StatServer, type=GA) synchronizing
request to 65202(--) message RequestDistributeEvent
AttributeExtensions [82] 00 04 00 00..
'SIGNATURE' 'router'
'NAME' 'URS1'
'VERSION' 'Version: 7.1.001.03'
'CLUSTER' 'URS1'
AttributeUserData [698] 00 1B 00 00..
'DNIS_NUM' '20005'
'CUSTID' 'CID:'
'RRequestedSkills'(list)
'CustomerSegment' 'default'
'ServiceType' 'default'
'ServiceObjective' ''
'DEBUG_GENESYS_DESTINATION' 'Switch_Tokyo'
'Site_ext' 'Tokyo'
'Skillname' 'Skill_A'
'SKILL_CODE' '21035'
'VAR_sTarget_val' '20842_Switch_Tokyo'
'VAR_sStatServer' 'StatServer'
'SubDN' '20779_Switch_Tokyo'
'RTargetRuleSelected' ''
'RTargetTypeSelected' '100'
'RTargetObjectSelected' ''
'RTargetAgentSelected' ''
'RTargetPlaceSelected' ''
'RTenant' 'Resources'
'RStrategyName' 'jump_to_routing'
'RTargetUsed'(list) 'TargetType' '100'
                    'TargetName' ''
'RRequestedSkillCombination' ''
'ReasonToCXU' 'noANI'
'VAR_nResult' '0'
'PegTD' 1
'ScriptName' ''
'VAR_sVQ' 'VQ_Skill_A_Tokyo'
AttributeDNIS '20005'
AttributeOtherDNRole 1
AttributeOtherDN '6003'
AttributeThisDNRole 2
AttributeThisQueue 'VQ_Skill_A'
AttributeThisDN 'VQ_Skill_A'
AttributeCallID 92
AttributeConnID 0092017974d65052
AttributeCustomerID 'Resources'
AttributeReferenceID 4294967295
AttributeUserEvent EventQueued
..sent to ctisssvp:5080(fd=16)
    _M_I_0092017974d65052 [17:0e] virtual queue "VQ_Skill_A_Tokyo"(id=293), VQ 101b8b6e0: target for routing was NOT SELECTED (0 0 0 1)
18:11:59.738_I_I_0092017974d65052 [09:04] <<<<<<<<<<<<suspend interpretator(WAIT_FOR_DN), timers:11000
18:11:59.738_B_I_0092017974d65052 [07:09] start chain of treatments
received from 65202(--)ctisssvp:5080(fd=16) message EventACK
AttributeTimeinuSecs 754024
AttributeTimeinSecs 1184749919 (18:11:59)
AttributeUserEvent RequestDistributeEvent
18:12:00.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1184749919, mem=0,90035,1399,16,123,0)
18:12:00.746_I_I_0092017974d65052 [07:08] wait time is over
18:12:00.746_I_I_0092017974d65052 [09:05] >>>>>>>>>>>>resume interpretator(0)
    _I_I_0092017974d65052 [09:04] ASSIGN: sTarget_out(LOCAL) <- STRING: return:timeout
    _I_I_0092017974d65052 [09:04] ASSIGN: nResult(LOCAL) <- INTEGER: 0
18:12:00.746_I_I_0092017974d65052 [07:48] suspend function
18:12:00.746_I_I_0092017974d65052 [09:04] <<<<<<<<<<<<suspend interpretator(JUMPING), timers:00001
18:12:00.746_I_I_0092017974d65052 [07:49] resume function
    _I_I_0092017974d65052 [07:44] jump to strategy *0x65*main_routing
    _I_I_0092017974d65052 [09:04] ASSIGN: sTarget_val(LOCAL) <- STRING: return:timeout
    _I_I_0092017974d65052 [09:04] ASSIGN: sPotentialTarget(LOCAL) <- STRING: VAG_Skill_A_L@StatServer.GA
    _I_I_0092017974d65052 [07:43] call strategy *0x65*sub_queue_call
18:12:00.746_I_I_0092017974d65052 [09:06] >>>>>>>>>>>>start interpretator
    _I_I_0092017974d65052 [07:46] no error mode for this call
    _I_I_0092017974d65052 [09:04] ASSIGN: __Return(SCRIPT) <- STRING:
    _I_I_0092017974d65052 [09:04] ASSIGN: __DBReturn(SCRIPT) <- STRING:
    _I_I_0092017974d65052 [09:04] ASSIGN: __DBStrReturn(SCRIPT) <- STRING:
    _I_I_0092017974d65052 [09:04] ASSIGN: __TargetVar(SCRIPT) <- STRING:
    _I_I_0092017974d65052 [09:04] ASSIGN: nTimeout_in(LOCAL) <- INTEGER: 9999
    _I_I_0092017974d65052 [09:04] ASSIGN: sTarget_in(LOCAL) <- STRING: VAG_Skill_A_L@StatServer.GA
    _I_I_0092017974d65052 [09:04] ASSIGN: sVQ_in(LOCAL) <- STRING: VQ_Skill_A_Tokyo
18:12:00.747_I_I_0092017974d65052 [07:26] HERE IS TARGETS
TARGETS: VAG_Skill_A_L@StatServer.GA
18:12:00.747_M_I_0092017974d65052 [13:01] current virtual queue: 101b7ef30 id=294, nVQ=1|39868980-101731c80, priority=0, time=1184749920.747
18:12:00.747_M_I_ [17:0c] VQ(101b842e0) created: type=0, tenant=Resources
    _M_I_ [17:06] VQ(101b842e0) target 101ba4f70 added: name=VAG_Skill_A_L, location=StatServer, type=GA, state=##state, activity=unknown
18:12:00.747_M_I_ [10:06] tenant Resources GroupAgents <VAG_Skill_A_L>: statistic ##content with server StatServer <request=19, status=2> asked
    _M_I_ [17:05] VQ(101b842e0) target (name=VAG_Skill_A_L, location=StatServer, type=GA) synchronizing
18:12:00.747_M_I_ [10:06] tenant Resources Agent <1602>: statistic ##state with server StatServer <request=13, status=2> asked
    _M_I_ [17:09] VQ(101b842e0), target 101ba4f70: GroupAgents <VAG_Skill_A_L> connected to state Agent 1602
18:12:00.747_M_I_ [10:06] tenant Resources Agent <1604>: statistic ##state with server StatServer <request=15, status=2> asked
    _M_I_ [17:09] VQ(101b842e0), target 101ba4f70: GroupAgents <VAG_Skill_A_L> connected to state Agent 1604
18:12:00.747_M_I_ [10:06] tenant Resources Agent <7999998>: statistic ##state with server StatServer <request=17, status=2> asked
    _M_I_ [17:09] VQ(101b842e0), target 101ba4f70: GroupAgents <VAG_Skill_A_L> connected to state Agent 7999998
18:12:00.747_M_I_0092017974d65052 [13:02] entering virtual queue "VQ_Skill_A_Tokyo"
    _M_I_ [17:0f] VQ(101b842e0) [at all 8 0] 1 target(s), flag=a, guid: 0Resources|VQ_Skill_A_Tokyo|1|-1|1|0|""|||01StatAgentLoading|00{}[]VAG_Skill_A_L@StatServer.GA
18:12:00.747_M_I_0092017974d65052 [13:03] call (virtual queue 101b7ef30, id=294, priority 0, time 1184749920.747) waits for VQ 101b842e0 (name="VQ_Skill_A_Tokyo") now
request to 65202(--) message RequestDeletePair
AttributeReferenceID 2692
AttributeDataKey 'RTargetAgentGroup'
AttributeThisDN '20719'
request to 65202(--) message RequestAttachUserData
AttributeReferenceID 2693
AttributeUserData [119] 00 03 00 00..
'RTargetAgentGroup' 'VAG_Skill_A_L'
'RTargetAgentGroup' 'VAG_Skill_A_M'
'RTargetAgentGroup' 'VAG_Skill_A_H'
'NAME' 'URS1'
'CLUSTER' 'URS1'
AttributeUserData [815] 00 1E 00 00..
'DNIS_NUM' '20005'
'CUSTID' 'CID:'
'Site_ext' 'Tokyo'
                    'TargetName' ''
'VAR_nResult' '0'
'PegTD' 1
'ScriptName' ''
AttributeCallID 92
AttributeUserEvent EventAttachedDataChanged
    _M_I_0092017974d65052 [17:0e] virtual queue "VQ_Skill_A_Tokyo"(id=294), VQ 101b842e0 (1 targets): SELECT MAX by statistic StatAgentLoading(random )
    _M_I_0092017974d65052 [17:0b] VQ 101b842e0 target "VAG_Skill_A_L" (#1, 3-2 components): SELECT MAX by statistic StatAgentLoading(random)
    _M_I_0092017974d65052 [17:0b] component #1 1602: not ready
    _M_I_0092017974d65052 [17:0b] component #2 1604: logged out
    _M_I_0092017974d65052 [17:0b] component #3 7999998: logged out
    _M_I_0092017974d65052 [17:0b] VQ 101b842e0 target "VAG_Skill_A_L": component was NOT SELECTED (2 1 0)
    _M_I_0092017974d65052 [17:0e] target VAG_Skill_A_L: not ready passed
    _M_I_0092017974d65052 [17:0e] virtual queue "VQ_Skill_A_Tokyo"(id=294), VQ 101b842e0: target for routing was NOT SELECTED (0 0 0 1)
  result of SelectDN: STRING: return:timeout
    _I_I_0092017974d65052 [07:27] HERE IS WAIT FOR DN (9999 sec)
18:12:00.748_B_I_0092017974d65052 [07:27] delay treatments for 0 msec
18:12:00.748_M_I_0092017974d65052 [10:1f] pulse for one call
    _T_I_0092017974d65052 [0E:19] check call routing states: state=10 delivery=0 treatment=0 held=0 reserving=0 - true
    _M_I_0092017974d65052 [17:0e] virtual queue "VQ_Skill_A_Tokyo"(id=292), VQ 101b7ed20 (1 targets): SELECT MAX by statistic StatAgentLoading(random )
    _M_I_0092017974d65052 [17:0e] target VAG_Skill_A_H: empty(0-0 components) passed
    _M_I_0092017974d65052 [17:0e] virtual queue "VQ_Skill_A_Tokyo"(id=292), VQ 101b7ed20: target for routing was NOT SELECTED (1 0 0 0)
    _M_I_0092017974d65052 [17:0e] virtual queue "VQ_Skill_A_Tokyo"(id=293), VQ 101b8b6e0 (1 targets): SELECT MAX by statistic StatAgentLoading(random )
    _M_I_0092017974d65052 [17:0b] VQ 101b8b6e0 target "VAG_Skill_A_M" (#1, 3-2 components): SELECT MAX by statistic StatAgentLoading(random)
    _M_I_0092017974d65052 [17:0b] VQ 101b8b6e0 target "VAG_Skill_A_M": component was NOT SELECTED (2 1 0)
    _M_I_0092017974d65052 [17:0e] target VAG_Skill_A_M: not ready passed
18:12:00.748_I_I_0092017974d65052 [09:04] <<<<<<<<<<<<suspend interpretator(WAIT_FOR_DN), timers:11000
18:12:00.748_B_I_0092017974d65052 [07:09] start chain of treatments
AttributeTimeinuSecs 764420
AttributeTimeinSecs 1184749920 (18:12:00)
18:12:02.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1184749921, mem=0,90047,1401,17,123,0)
18:12:02.186 Trc 20011 current number of targets for tenant Resources: Agents 11, Places 0, AgentGroups 6, PlaceGroups 0, ACDQueues 0, Routing Points 6
18:12:02.186 Trc 20012 current number of interactions per second - 1.00
18:12:02.186 Trc 20013 current number of entries: for longest queue 0, for all queues 0
18:12:04.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1184749923, mem=0,90047,1401,17,123,0)
18:12:04.376_M_I_ [17:0d] VQ(101b81480) deleted
18:12:04.376_M_I_ [17:08] VQ(101b81480) target 101ba4c40 deleted: name=VAG_Skill_B_L
18:12:04.376_M_I_ [17:0d] VQ(101b811e0) deleted
18:12:04.376_M_I_ [17:08] VQ(101b811e0) target 101b812f0 deleted: name=VAG_Skill_B_M
18:12:04.376_M_I_ [17:0d] VQ(101b906c0) deleted
18:12:04.376_M_I_ [17:08] VQ(101b906c0) target 1019c53d0 deleted: name=VAG_Skill_B_H
18:12:06.016_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1184749925, mem=0,90014,1395,14,123,0)
18:12:08.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=2, time=1184749927, mem=0,90014,1395,14,123,0)
18:12:09.776_M_I_ [17:0d] VQ(101b905b0) deleted
18:12:09.776_M_I_ [17:08] VQ(101b905b0) target 101b9dc20 deleted: name=20717_Switch_Tokyo
18:12:10.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=1, time=1184749929, mem=0,90004,1393,13,123,0)
18:12:10.756_M_I_ [17:0d] VQ(101b9a7d0) deleted
18:12:10.756_M_I_ [17:08] VQ(101b9a7d0) target 101b9de60 deleted: name=20719_Switch_Tokyo
18:12:12.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749931, mem=0,89994,1391,12,123,0)
18:12:14.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749933, mem=0,89994,1391,12,123,0)
18:12:16.016_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749935, mem=0,89994,1391,12,123,0)
18:12:18.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749937, mem=0,89994,1391,12,123,0)
18:12:20.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749939, mem=0,89994,1391,12,123,0)
18:12:22.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749941, mem=0,89994,1391,12,123,0)
18:12:24.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749943, mem=0,89994,1391,12,123,0)
18:12:26.016_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749945, mem=0,89994,1391,12,123,0)
18:12:28.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749947, mem=0,89994,1391,12,123,0)
18:12:30.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749949, mem=0,89994,1391,12,123,0)
18:12:32.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749951, mem=0,89994,1391,12,123,0)
18:12:34.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749953, mem=0,89994,1391,12,123,0)
18:12:36.016_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749955, mem=0,89994,1391,12,123,0)
18:12:38.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749957, mem=0,89994,1391,12,123,0)
18:12:40.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749959, mem=0,89994,1391,12,123,0)
18:12:42.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749961, mem=0,89994,1391,12,123,0)
18:12:44.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749963, mem=0,89994,1391,12,123,0)
18:12:46.015_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749965, mem=0,89994,1391,12,123,0)
18:12:48.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749967, mem=0,89994,1391,12,123,0)
18:12:50.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749969, mem=0,89994,1391,12,123,0)
18:12:51.617_G_I_ [01:0b] look for hanged interactions: 1 at all now
18:12:51.617_G_I_ [01:0b] there are 1 calls in progress now
_G_I_ Version: 7.1.001.03
root 1009b7830
18:12:52.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749971, mem=0,89994,1391,12,123,0)
18:12:54.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749973, mem=0,89994,1391,12,123,0)
18:12:56.016_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749975, mem=0,89994,1391,12,123,0)
18:12:58.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749977, mem=0,89994,1391,12,123,0)
18:12:58.726_M_I_0092017974d65052 [07:0d] default priority 1
18:12:58.726_M_I_0092017974d65052 [13:05] current priority for all VQ(s) increased by 1
18:12:58.726_M_I_0092017974d65052 [13:03] call (virtual queue 101b7ef30, id=294, priority 0) doesn't wait for VQ 101b842e0 (name="VQ_Skill_A_Tokyo") now
18:12:58.727_M_I_0092017974d65052 [13:03] call (virtual queue 101b7ef30, id=294, priority 1, time 1184749920.747) waits for VQ 101b842e0 (name="VQ_Skill_A_Tokyo") now
18:12:58.727_M_I_0092017974d65052 [13:03] call (virtual queue 101b809f0, id=293, priority 0) doesn't wait for VQ 101b8b6e0 (name="VQ_Skill_A_Tokyo") now
18:12:58.727_M_I_0092017974d65052 [13:03] call (virtual queue 101b809f0, id=293, priority 1, time 1184749919.737) waits for VQ 101b8b6e0 (name="VQ_Skill_A_Tokyo") now
18:12:58.727_M_I_0092017974d65052 [13:03] call (virtual queue 101ba2f40, id=292, priority 0) doesn't wait for VQ 101b7ed20 (name="VQ_Skill_A_Tokyo") now
18:12:58.727_M_I_0092017974d65052 [13:03] call (virtual queue 101ba2f40, id=292, priority 1, time 1184749918.727) waits for VQ 101b7ed20 (name="VQ_Skill_A_Tokyo") now
18:13:00.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749979, mem=0,89994,1391,12,123,0)
18:13:02.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749981, mem=0,89994,1391,12,123,0)
18:13:04.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749983, mem=0,89994,1391,12,123,0)
18:13:06.016_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749985, mem=0,89994,1391,12,123,0)
18:13:08.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749987, mem=0,89994,1391,12,123,0)
18:13:10.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749989, mem=0,89994,1391,12,123,0)
18:13:12.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749991, mem=0,89994,1391,12,123,0)
18:13:14.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749993, mem=0,89994,1391,12,123,0)
18:13:16.015_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749995, mem=0,89994,1391,12,123,0)
18:13:18.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749997, mem=0,89994,1391,12,123,0)
18:13:20.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184749999, mem=0,89994,1391,12,123,0)
18:13:22.006_M_I_ [10:1d] PULSE (calls: 1(1)=1+0-0, targets=0, time=1184750001, mem=0,89994,1391,12,123,0)
18:13:24.006_M_I_ [10:1d] PULSE (calls: 2(2)=1+4-3, targets=2, time=1184750003, mem=0,90077,1396,16,124,0)
18:13:24.376_B_I_0092017974d65053 [14:apply_treatment_postproc] treatment timer is activated in APPLIED state
18:13:24.377_M_I_ [10:06] tenant Resources Agent <1704>: statistic ##state with server StatServer_Oak <request=3, status=2> asked
    _M_I_ [17:09] VQ(101b90640), target 101b90750: GroupAgents <VAG_Skill_B_H> connected to state Agent 1704
'NAME' 'URS1'
'CLUSTER' 'URS1'
AttributeUserData [686] 00 1B 00 00..
'DNIS_NUM' '20003'
'CUSTID' 'CID:'
'Site_ext' 'Tokyo'
'Skillname' 'Skill_B'
'SKILL_CODE' '21030'
'VAR_sTarget_val' '20841_Switch_Tokyo'
'SubDN' '20777_Switch_Tokyo'
                    'TargetName' ''
'VAR_nResult' '0'
'PegTD' 1
'ScriptName' ''
'VAR_sVQ' 'VQ_Skill_B_Tokyo'
AttributeDNIS '20003'
AttributeOtherDN '6001'
AttributeThisQueue 'VQ_Skill_B'
AttributeThisDN 'VQ_Skill_B'
AttributeCallID 93
AttributeConnID 0092017974d65053
    _M_I_0092017974d65053 [17:0e] virtual queue "VQ_Skill_B_Tokyo"(id=298), VQ 101b81270: target for routing was NOT SELECTED (0 1 0 0)
18:13:25.388_I_I_0092017974d65053 [09:04] <<<<<<<<<<<<suspend interpretator(WAIT_FOR_DN), timers:11000
18:13:25.388_B_I_0092017974d65053 [07:09] start chain of treatments
AttributeTimeinuSecs 404057
AttributeTimeinSecs 1184750005 (18:13:25)
18:13:26.016_M_I_ [10:1d] PULSE (calls: 2(2)=2+0-0, targets=2, time=1184750005, mem=0,90105,1400,18,124,0)
18:13:26.396_I_I_0092017974d65053 [07:08] wait time is over
18:13:26.396_I_I_0092017974d65053 [09:05] >>>>>>>>>>>>resume interpretator(0)
    _I_I_0092017974d65053 [09:04] ASSIGN: sTarget_out(LOCAL) <- STRING: return:timeout
    _I_I_0092017974d65053 [09:04] ASSIGN: nResult(LOCAL) <- INTEGER: 0
18:13:26.396_I_I_0092017974d65053 [07:48] suspend function
18:13:26.396_I_I_0092017974d65053 [09:04] <<<<<<<<<<<<suspend interpretator(JUMPING), timers:00001
18:13:26.396_I_I_0092017974d65053 [07:49] resume function
    _I_I_0092017974d65053 [07:44] jump to strategy *0x65*main_routing
    _I_I_0092017974d65053 [09:04] ASSIGN: sTarget_val(LOCAL) <- STRING: return:timeout
    _I_I_0092017974d65053 [09:04] ASSIGN: sPotentialTarget(LOCAL) <- STRING: VAG_Skill_B_L@StatServer_Oak.GA
    _I_I_0092017974d65053 [07:43] call strategy *0x65*sub_queue_call
18:13:26.396_I_I_0092017974d65053 [09:06] >>>>>>>>>>>>start interpretator
    _I_I_0092017974d65053 [07:46] no error mode for this call
    _I_I_0092017974d65053 [09:04] ASSIGN: __Return(SCRIPT) <- STRING:
    _I_I_0092017974d65053 [09:04] ASSIGN: __DBReturn(SCRIPT) <- STRING:
    _I_I_0092017974d65053 [09:04] ASSIGN: __DBStrReturn(SCRIPT) <- STRING:
    _I_I_0092017974d65053 [09:04] ASSIGN: __TargetVar(SCRIPT) <- STRING:
    _I_I_0092017974d65053 [09:04] ASSIGN: nTimeout_in(LOCAL) <- INTEGER: 9999
    _I_I_0092017974d65053 [09:04] ASSIGN: sTarget_in(LOCAL) <- STRING: VAG_Skill_B_L@StatServer_Oak.GA
    _I_I_0092017974d65053 [09:04] ASSIGN: sVQ_in(LOCAL) <- STRING: VQ_Skill_B_Tokyo
18:13:26.397_I_I_0092017974d65053 [07:26] HERE IS TARGETS
TARGETS: VAG_Skill_B_L@StatServer_Oak.GA
18:13:26.397_M_I_0092017974d65053 [13:01] current virtual queue: 101b79cd0 id=299, nVQ=1|39868980-101731c80, priority=0, time=1184750006.397
18:13:26.397_M_I_ [17:0c] VQ(101b96230) created: type=0, tenant=Resources
    _M_I_ [17:06] VQ(101b96230) target 101b96340 added: name=VAG_Skill_B_L, location=StatServer_Oak, type=GA, state=##state, activity=unknown
18:13:26.397_M_I_ [10:06] tenant Resources GroupAgents <VAG_Skill_B_L>: statistic ##content with server StatServer_Oak <request=15, status=2> asked
    _M_I_ [17:05] VQ(101b96230) target (name=VAG_Skill_B_L, location=StatServer_Oak, type=GA) synchronizing
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1701>: statistic ##state with server StatServer_Oak <request=17, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1701
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1602>: statistic ##state with server StatServer_Oak <request=7, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1602
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1702>: statistic ##state with server StatServer_Oak <request=19, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1702
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1703>: statistic ##state with server StatServer_Oak <request=9, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1703
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1802>: statistic ##state with server StatServer_Oak <request=21, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1802
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1604>: statistic ##state with server StatServer_Oak <request=11, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1604
18:13:26.397_M_I_ [10:06] tenant Resources Agent <1704>: statistic ##state with server StatServer_Oak <request=3, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 1704
18:13:26.397_M_I_ [10:06] tenant Resources Agent <7999998>: statistic ##state with server StatServer_Oak <request=13, status=2> asked
    _M_I_ [17:09] VQ(101b96230), target 101b96340: GroupAgents <VAG_Skill_B_L> connected to state Agent 7999998
18:13:26.397_M_I_0092017974d65053 [13:02] entering virtual queue "VQ_Skill_B_Tokyo"
    _M_I_ [17:0f] VQ(101b96230) [at all 8 0] 1 target(s), flag=a, guid: 0Resources|VQ_Skill_B_Tokyo|1|-1|1|0|""|||01StatAgentLoading|00{}[]VAG_Skill_B_L@StatServer_Oak.GA
18:13:26.397_M_I_0092017974d65053 [13:03] call (virtual queue 101b79cd0, id=299, priority 0, time 1184750006.397) waits for VQ 101b96230 (name="VQ_Skill_B_Tokyo") now
AttributeReferenceID 2726
AttributeReferenceID 2727
AttributeUserData [101] 00 03 00 00..
'RTargetAgentGroup' 'VAG_Skill_B_L'
'RTargetAgentGroup' 'VAG_Skill_B_M'
'RTargetAgentGroup' 'VAG_Skill_B_H'
'NAME' 'URS1'
'CLUSTER' 'URS1'
AttributeUserData [785] 00 1E 00 00..
'DNIS_NUM' '20003'
'CUSTID' 'CID:'
'Site_ext' 'Tokyo'
                    'TargetName' ''
'VAR_nResult' '0'
'PegTD' 1
'ScriptName' ''
AttributeCallID 93
    _M_I_0092017974d65053 [17:0e] virtual queue "VQ_Skill_B_Tokyo"(id=299), VQ 101b96230 (1 targets): SELECT MAX by statistic StatAgentLoading(random )
    _M_I_0092017974d65053 [17:0b] VQ 101b96230 target "VAG_Skill_B_L" (#1, 8-7 components): SELECT MAX by statistic StatAgentLoading(random)
    _M_I_0092017974d65053 [17:0b] component #1 1701: logged out
    _M_I_0092017974d65053 [17:0b] component #2 1602: not ready
    _M_I_0092017974d65053 [17:0b] component #3 1702: logged out
    _M_I_0092017974d65053 [17:0b] component #4 1703: logged out
    _M_I_0092017974d65053 [17:0b] component #5 1802: logged out
    _M_I_0092017974d65053 [17:0b] component #6 1604: logged out
    _M_I_0092017974d65053 [17:0b] component #7 1704: logged out
    _M_I_0092017974d65053 [17:0b] component #8 7999998: logged out
    _M_I_0092017974d65053 [17:0b] VQ 101b96230 target "VAG_Skill_B_L": component was NOT SELECTED (7 1 0)
    _M_I_0092017974d65053 [17:0e] target VAG_Skill_B_L: not ready passed
    _M_I_0092017974d65053 [17:0e] virtual queue "VQ_Skill_B_Tokyo"(id=299), VQ 101b96230: target for routing was NOT SELECTED (0 0 0 1)
    _I_I_0092017974d65053 [07:27] HERE IS WAIT FOR DN (9999 sec)
18:13:26.398_B_I_0092017974d65053 [07:27] delay treatments for 0 msec
18:13:26.398_M_I_0092017974d65053 [10:1f] pulse for one call
    _T_I_0092017974d65053 [0E:19] check call routing states: state=10 delivery=0 treatment=0 held=0 reserving=0 - true
    _M_I_0092017974d65053 [17:0e] virtual queue "VQ_Skill_B_Tokyo"(id=297), VQ 101b90640 (1 targets): SELECT MAX by statistic StatAgentLoading(random )
    _M_I_0092017974d65053 [17:0e] target VAG_Skill_B_H: empty(1-1 components) passed
    _M_I_0092017974d65053 [17:0e] virtual queue "VQ_Skill_B_Tokyo"(id=297), VQ 101b90640: target for routing was NOT SELECTED (0 1 0 0)
    _M_I_0092017974d65053 [17:0e] virtual queue "VQ_Skill_B_Tokyo"(id=298), VQ 101b81270 (1 targets): SELECT MAX by statistic StatAgentLoading(random )
    _M_I_0092017974d65053 [17:0e] target VAG_Skill_B_M: empty(4-4 components) passed
18:13:26.398_I_I_0092017974d65053 [09:04] <<<<<<<<<<<<suspend interpretator(WAIT_FOR_DN), timers:11000
18:13:26.398_B_I_0092017974d65053 [07:09] start chain of treatments
AttributeTimeinuSecs 414564
AttributeTimeinSecs 1184750006 (18:13:26)
18:13:28.006_M_I_ [10:1d] PULSE (calls: 2(2)=2+0-0, targets=2, time=1184750007, mem=0,90117,1402,19,124,0)
18:13:29.267_M_I_ [10:17] CHANGE OF STATE (tenant Resources object 1602 statserver StatServer_Oak)
    _M_I_ [10:17] ready DN(switch Switch_Tokyo, number 6002, type 2, time= 1184750009) for agent 1602, place Place_6002_Tokyo, status WaitForNextCall time= 1184750009
    _M_I_ [10:17] tenant Resources object 1602 statserver StatServer_Oak: 1 ready DNs reported
18:13:29.267_M_I_ [10:15] check queue for statobject <1602> type <Agent>
WAITING CALLS: 0092017974d65053
    _M_I_0000000000000000 [10:20] try to route to agent "1602" (place "Place_6002_Tokyo", 1 ready DNs reported)
18:13:29.267_M_I_ [10:0a] object Place_6002_Tokyo|Resources| is unblocked
    _M_I_ [10:0b] agent 1602, place Place_6002_Tokyo, switch  dn  isn't blocked absolutely(0)
    _M_I_0092017974d65053 [10:21] try to route to agent "1602" (place "Place_6002_Tokyo", 1 ready DNs reported)
18:13:29.267_M_I_ [10:0a] object 1602|Resources| is unblocked
18:13:29.267_M_I_ [10:0a] object 6002|Switch_Tokyo| is unblocked
    _M_I_0092017974d65053 [01:0d] attempt to route (1)
========== DN Information ===========
DN Number 6002
Agent Name 1602
Place Name Place_6002_Tokyo
Agent Login 1602
Switch Name Switch_Tokyo
DN Type 2
====================== Target Information =====================
Target Name    < VAG_Skill_B_L >
Target Location < StatServer_Oak >
Target Type    < GA >
STATE MAPPING INFO - STATISTIC < ##state >:
Stat Server DN info available
Modelling Statistic  : NOT available
18:13:29.267_X_I_0092017974d65053 [06:04] send to tserver TServer_G3r_Tokyo_2 TReserveAgent (dn=6002@Switch_Tokyo, name=1602, place=Place_6002_Tokyo, priorities=0,3,602)
request to 65202(--) message RequestReserveAgent
AttributeReferenceID 2728
AttributeExtensions [71] 00 03 01 00..
'ar-priority-1' 3
'ar-priority-2' 602
'CUSTOMER_ID' 'Resources'
AttributePriority 0
AttributeTimeout 15000
AttributePlace 'Place_6002_Tokyo'
AttributeAgentID '1602'
AttributeThisDN '6002@Switch_Tokyo'
18:13:29.268_M_I_0092017974d65053 [10:1b] blocking: agent 1602, place Place_6002_Tokyo, switch Switch_Tokyo dn 6002 is blocked for 15 sec by 275 expired 1184750024
    _M_I_0092017974d65053 [10:21] LAUNCHED (dn=6002)
18:13:29.268_M_I_ [10:17] CHANGE OF STATE (tenant Resources object 1602 statserver StatServer)
    _M_I_ [10:17] tenant Resources object 1602 statserver StatServer: 1 ready DNs reported
18:13:29.268_M_I_ [10:15] check queue for statobject <1602> type <Agent>
WAITING CALLS: 0092017974d65052 0092017974d65052
    _M_I_ [10:0b] agent 1602, place Place_6002_Tokyo, switch  dn  isn't blocked absolutely(275)
    _M_I_0092017974d65052 [10:21] try to route to agent "1602" (place "Place_6002_Tokyo", 1 ready DNs reported)
    _M_I_0092017974d65052 [10:21] agent 1602, place Place_6002_Tokyo, switch  dn  is blocked with call 275 (15 sec from 1184750009)
received from 65202(--)ctisssvp:5080(fd=16) message EventAgentReserved
AttributeTimeinuSecs 376601
AttributeTimeinSecs 1184750009 (18:13:29)
[/code]
« Reply #9 on: July 24, 2007, 04:11:13 AM »
Interesting, and what does StatServer says?
Which PBX are you using? A Nortel?
Can you share your ird strategies? I'll like to test with an Alcatel OXE.
Also would like to try without Virtual Queues.
« Reply #10 on: July 24, 2007, 05:19:41 AM »
Cavagnaro,
I am using Genesys Avaya-simulator and 7.2 StatServer.  I doubt that PBX would matter since routing logic is controlled by URS. One thing that I am curious is we use SelectDN() and SuspendForDN() instead of a bit more standard Select-DN block object... I doubt that it would matter though...
Try several tests and see if you can replicate it. One thing to be careful with is that it seems like if you place call to first then second then the first then the second, it will sometimes be difficult to recreate this problem, so I suggest placing first call into queue A, then place call second call into queue B then let agent receive both calls. Then try placing a call to queue B, wait 1 minute and then place a call to queue A and then let agent get the calls. So, it is A->wait 1 minute->B->get both calls->B->wait 1 min->A->get both calls->B->wait 1 minute->A->get both calls.
Seems to cause the problem almost every time during this sort of sequence.
SOLVED: Re: How does URs handle multi-queue routing?
« Reply #11 on: August 17, 2007, 07:55:34 AM »
Ok, it seems like I figured the problem (and Genesys tech support managed to get back to us about a day later to confirm it  ;D ).
0092017974d65052 has a higher priority than 0092017974d65053 and therefore it should be routed to the agent first, BUT because we use StatServer for Skill_A and StatServer_Oak for Skill_B, URS somehow no longer routes according to priority but what seems to be at random .
So, the lesson is: URS does not take priority of the call when targets are using stats from different StatServers. And this, my friends, makes little sense since priority is maintained by URS and not StatServer, so why in the world would it care about it?
Genesys might call it whatever they want, but in my book, this is a bug.
URSMan
« Reply #12 on: August 17, 2007, 08:35:05 AM »
Vic,
also do not forget that priority is not shared between URS. You can have priority 0 call on URS 1 and priority 100 on URS 2 and still get priority 0 call before priority 100.
[move]URSMan Rulez[/move]
« Reply #13 on: August 17, 2007, 08:53:45 AM »
URSMan,
I don't think it is true. Obviously, URS2 is not informed of priority of call in URS1, but T-Server should be able to distinguish between two by looking at AttributePriority which contains that call's priority level.
As long as it is within the timeout I cannot remember the name of that controls how long T-Server waits for other reservation requests before replying, then T-Server will reply to one and reject the other.
Damn, if I only remembered the option name. I think it was agent-reservation-wait or something like that...
Offline Kevin S
« Reply #14 on: August 17, 2007, 12:44:24 PM »
Victor, it's not a bug, it's an "Undocumented Feature"...
