" /> Error 51 on blind(single step) transfer - Genesys CTI User Forum
Author Topic: Error 51 on blind(single step) transfer  (Read 4804 times)
subzero
« on: August 29, 2007, 08:49:03 AM »
I'm using verson 7.2.
When running blind transfer (final call is to TeleCall.singleStepTransfer() method)
We get EventError with
ErrorCode          51
The Event (TeleEvent) has no error message.
The Event is accepted at the initiator agent side - the call never reached the second agent.
Since I have no access to the T-Server log, I don't have any clue what does this error mean.
Please advise.
Dror.
Offline mark
Re: Error 51 on blind(single step) transfer
« Reply #1 on: August 29, 2007, 09:44:51 AM »
If you call the number does it answer?
Would be good to get access to the logs, or get the corresponding log file sent to you.
Mark
subzero
« Reply #2 on: August 29, 2007, 01:07:13 PM »
The second number can be called.
Actually two step transfer works fine. It's just the one step transfer which fails
Marked as best answer by on August 10, 2025, 08:31:54 PM
Offline JTL
« Reply #3 on: August 29, 2007, 03:59:47 PM »
  • Undo Best Answer
  • Have you tried TMuteTransfer instead of TSingleStepTransfer?
