" /> CCP historical shows *Error* for formulae - Genesys CTI User Forum
Author Topic: CCP historical shows *Error* for formulae  (Read 3372 times)
Offline daveg
« on: September 05, 2007, 03:41:44 PM »
We use several formulae in CCP which work fine in the realtime display. But when we do a CCP historical report using the same template some - but not all - formulae show as "*Error*". We're just calculating percentages from the staandard stats, nothing complex.
Any ideas?
tony
Re: CCP historical shows *Error* for formulae
« Reply #1 on: September 05, 2007, 08:18:57 PM »
I think it might be an idea to define which stats are showing the error.  Perhaps you could screenshot the composition of one of them... Let the fox see the rabbit, so to speak...  ;)
Tony
« Reply #2 on: September 05, 2007, 11:55:30 PM »
Usually that appears when dividing by zero
Offline daveg
« Reply #3 on: September 06, 2007, 08:11:34 AM »
Oops! Failed to associate one of the stats with a historical table! No wonder it errored. Sorry!
tony
« Reply #4 on: September 06, 2007, 07:46:50 PM »
6 out of 10 for effort...  ;)
