" /> CallConsultOriginated / CallConsultReceived - time based stats? - Genesys CTI User Forum
Author Topic: CallConsultOriginated / CallConsultReceived - time based stats?  (Read 4312 times)
Offline JTL
« on: September 06, 2007, 02:59:53 PM »
Hope someone can fill me in on this one...
I've been ploughing through with our consult call business requirements. Have created some N_Consult_Rec and N_Consult_Orig stats to count the number of made/received Consult calls. This works fine.
We also have N_Consult and T_Consult statistics which count the "number" and "talk time" of consult calls.
However, it has now gone a bit pear-shaped, since I tried to create T_Consult_Rec and T_Consult_Orig - using a copy of the T_Consult statistic, except with the CallConsultReceived or CallConsultOriginated actions instead.
On reading the Genesys manuals, I thought this should work, since they are apparently durable (not momentary) actions.
However, when I create a reporting template and layout, and begin to collect stats based on a sample call, I see T_Consult increment correctly, and I see the N_Consult_Orig and N_Consult_Rec stats increment correctly, but NOT the T_Consult_Orig and T_Consult_Rec (time based) stats.
It is:
Category=TotalTime
Description=Total Consult Originated Talk Time
MainMask=CallConsultOriginated
Objects=Agent, GroupAgents, GroupPlaces, Place
Subject=AgentStatus
Which is exactly the same as our (working) T_Consult, except the MainMask is different...
So why isn't this working?????????
Re: CallConsultOriginated / CallConsultReceived - time based stats?
« Reply #1 on: September 06, 2007, 03:32:51 PM »
As AgentStatus? I believe it should work as DNAction as CallConsultOriginated is not an AgentStatus
Offline JTL
« Reply #2 on: September 06, 2007, 03:35:22 PM »
[quote author=cavagnaro link=topic=2452.msg9273#msg9273 date=1189092771]
As soon as I typed that up, I wondered if Agent Status might have anything to do with it since the CallConsult is likely to be the overriding action on the Agent at the time... yes?
I will try again with DNAction and report back :)
Offline JTL
« Reply #3 on: September 07, 2007, 08:18:24 AM »
Good call.
Tried again this morning, T_Consult of 76 seconds for both agents, T_Consult_Orig of 76 for Agent A, and T_Consult_Rec of 76 for Agent B.
Perfick!
« Reply #4 on: September 07, 2007, 04:08:58 PM »
:) Good to know
