" /> Historical Reporting - Genesys CTI User Forum
Author Topic: Historical Reporting  (Read 4080 times)
Genesys31
« on: September 26, 2007, 10:20:09 AM »
When we generate a hestorical report the item total answer calls  appear as average (Not Number).
the configuration seems OK, any idea?
Offline mark
Re: Historical Reporting
« Reply #1 on: September 26, 2007, 10:56:53 AM »
  • Hi,
    Is this from CCPulse+ or from CCA?
    What is the stat that is actually being used?
    What is the stat reporting against? agent / group / dn etc?
    Mark
    « Last Edit: September 26, 2007, 10:59:04 AM by mark »
    « Reply #2 on: September 26, 2007, 01:14:25 PM »
  • I'd think of CCPulse, go to your View Definition (Template Wizard) and on that Stat > Properties > Historical Association verify that you have N_ANSWERED instead of AVG_ANSWERED
    Genesys31
    « Reply #3 on: September 27, 2007, 11:44:13 AM »
  • it is CCPulse+, i checked the configuration and it is configured as N_ANSWERED and i am still getting the average value not the total number of answered calls
    « Reply #4 on: September 27, 2007, 01:46:57 PM »
  • Ok, now go to DMA and seek for that N_ANSWERED, check how it is defined on the statistical type.
