" /> CC pulse and ServiceFactor1 - Genesys CTI User Forum
Author Topic: CC pulse and ServiceFactor1  (Read 9625 times)
dink
« on: November 08, 2007, 10:10:54 AM »
My customer wants to have PCA30, i.e percentage of call answered within 30 seconds. I used the ServiceFactor1 statiscal type with TimeRange 0-30 and TimeRange1 0-5;
Situation
. nr calls offered 3
. nr call answered within 30 sec: 1
. nr calls abandoned: 2
. nr calls short abandoned: 1
the servicefactor1 calculates as follows 100 * nrcallsanswered0-30/ (nrcallsanswered0-30 + nrcallsabandonded - nrcallsabadoned0-5) = 100 * (1 /1+2-1)= 50%
However it is clear that this should be 33%
Any idea how to implement tihs ?
Re: CC pulse and ServiceFactor1
« Reply #1 on: November 08, 2007, 11:14:25 AM »
  • Hi,
    You can use custom statistic in CCPulse to count the value using your formula:
    [code]PCA30 = nrcallsoffered / nrcallsanswered0-30[/code]
    René
    Offline Kevin S
    « Reply #2 on: November 08, 2007, 12:33:52 PM »
  • dink -
    Check your math again. In your denominator, 1 + 2 - 1 = 2, not 3.
    Therefore 100 * 1 / (1 + 2 - 1) = 100 * 1 / 2 = 50%
    Also, the formula you propose is incorrect for ServiceFactor1. It should be:
    SF1 = 100 * Answered0-30 / (Answered + Abandoned - Abandoned0-5)
    In the denominator, you need to use ALL the answered calls in the calculation.
    Rene -
    I think your formula should be flipped
    PCA30 = nrcallsanswered0-30 / nrcallsoffered
    Otherwise, it will always equal or exceed 100%, since Offered >= Answered0-30.
    dink
    « Reply #3 on: November 08, 2007, 01:56:33 PM »
  • Kevin,
    what is wrong with my math; I wrote it is 50%; it should be 33%;
    Offline Kevin S
    « Reply #4 on: November 08, 2007, 03:12:34 PM »
  • I'll rephrase the question...
    Why do you think it should be 33%?
    « Reply #5 on: November 08, 2007, 03:25:15 PM »
  • Bink, you are only considering the calls answered on the first 30 seconds, as Kevin says, you must consider ALL answered, no matter on what time they were answered. I believe that is your confusion.
    You can check reporting guide to have more clear concept, or maybe your client is using a completly different formula for what he considers his SF should be.
    dink
    « Reply #6 on: November 08, 2007, 03:54:33 PM »
  • I agree that I have to consider all calls (that was just a typo error)
    But it has to be 33 because there are 3 calls offered and only 1 is answered within 30 seconds
    I have a easy solution using a formula within the template of CC pulse. But for organisational reasons, they prefer a solution on stat server level
    « Reply #7 on: November 08, 2007, 06:04:01 PM »
  • Dink,
    As I know there is no possibility to define custom formulas on StatServer level.
    to Kevin: Thanks for correction. My hands were quicker than my brain ;-)
    René
    « Reply #8 on: November 08, 2007, 07:07:41 PM »
  • However it is clear that this should be 33% ACCORDING TO YOUR PERSONAL FORMULA NOT ACCORDING TO STATSERVER FORMULA should be your consideration
    Remember:
    SF1 = answered_threshold * 100 / (answered + abandon - short_abandon)
    So for your data:
    1*100/ 3 + 2 - 1
    100/ 4
    25% is your SF...
    . nr calls offered 3 (answered is not equal as entered)
    dink
    « Reply #9 on: November 09, 2007, 10:37:23 AM »
  • now your maths are wrong cava
    it is 1/(2 + 1 -1) * 100 = 50 %
    i' ve never metioned that it is wrong; i have only said that my customer does not accept it; so i will go for a custom formula
    does anyone know where I can find info that explains how I can put a formula on the level of the stat server; the stat server reference manual is very cryptic on this issue
    « Reply #10 on: November 09, 2007, 02:25:53 PM »
  • And that 2 came from....???
    For custom "Formulas" read the main and relative masks section, not so hard and very clear.
    Offline Kevin S
    « Reply #11 on: November 09, 2007, 02:51:40 PM »
  • Rene -
    Not a prob - Been there, done that...
    dink
    « Reply #12 on: November 12, 2007, 11:40:07 AM »
  • cava,
    2 is the number of abandoned calls (1 nomral - 1 short abandoned)
    dink
    « Reply #13 on: November 12, 2007, 03:49:24 PM »
  • Ok,
    But how do you think your stat should be?
    Because you say:
    [quote]
    But you don't say why you think that.
    Offline Sylvainsjc
    « Reply #14 on: November 12, 2007, 04:05:17 PM »
  • Someone have aspirin ???
