" /> Importing Excel files into DNC list - Genesys CTI User Forum
Author Topic: Importing Excel files into DNC list  (Read 5017 times)
DaveJ
« on: November 15, 2007, 02:32:44 PM »
I've been handed a list of 4000 telephone numbers in Excel format.  Can anyone assist with how i would transfer these records into a suitable format for Genesys?  I've been advised to use a .dat file?
Thanks in advance
Re: Importing Excel files into DNC list
« Reply #1 on: November 15, 2007, 04:18:45 PM »
I'd recoomend to input a record by hand, export it as you will see how you need to format your data
« Reply #2 on: November 15, 2007, 04:25:37 PM »
You can use Outbound Contact Manager (OCM) to upload list of DNC numbers. It supports "csv" file format. Unfortunately, I don't have access to OCM now so I can't provide you with more details but there is detailed step-by-step description how to do it in "Outbound Contact Deployment Guide".
René
« Reply #3 on: November 15, 2007, 04:33:13 PM »
Well just to mention that my procedure is also with OCM. If you only have one record you will import it and when ready OCM will ask you what field is that, it can be the number or the customer_id (read OCS deplyment guide on how to use this special column).
Marked as best answer by on Today at 06:55:34 AM
DaveJ
« Reply #4 on: November 15, 2007, 05:45:43 PM »
  • Undo Best Answer
  • I am using OCM as well, so if i was to change the excel file to a csv file would i be able to import the list, or is there any other formatting i would need to consider?
    Thanks again.
    « Reply #5 on: November 15, 2007, 05:54:32 PM »
    csv, txt, no matter, just consider the right format, for you to get a better idea export a record and see how it is used.
    Offline jbobinsk
    « Reply #6 on: November 16, 2007, 10:31:53 AM »
    You have to only know what format is accepted from Genesys site for DNC List.
    You have it described in Deployment Guide for Outbound solution.
    Exporting from Excel may be done with macro behinde which you will program it's quite easy for example:
    Sub Export()
      Dim hndl as Integer
      Dim var_FileName as String 'you have to assign it with file path and name
      Dim Bufor as string
      Dim var_row as integer
      Dim var_column as integer
    hndl=FreeFile
    Open var_FileName For Output As #hndl
    For var_row=1 to ActiveSheet.UsedRange.Rows.Count
      For var_column to ActiveSheet.UsedRange.Columns.Count
          Bufor=Bufor & "," & ActiveSheet.Cells(var_row,var_column)
      Next
      Bufor=Mid(Bufor,2)
      Print #hndl,bufor
    Next
    Close
    end Sub
    You have to test it because I have written it write now without testing. The name of File should be with *.csv.
    Regards
    Jacek Bobinski
