" /> Using schedule files with IR - Genesys CTI User Forum
Author Topic: Using schedule files with IR  (Read 4114 times)
Akiko Matsuda
Good morning, I have a problem with schedule files used with interaction router server. I created a schedule file, but I do not understand how to tell interaction router server to use this schedule. Is there an option I have to use when starting interaction server? I thank you very much for your help. Akiko Matsuda SOFTWARE DEVELOPER SYSTEM ENGINEERING GROUP CTC
Victor
  • This one is easy :) You use Strategy Loader to do that if you select Preload and look under file extensions, you will find *.sch for schedule files. I hope it helped! Vic
