" /> SCI and Tomcat 5.5 running as a windows service? - Genesys CTI User Forum
Author Topic: SCI and Tomcat 5.5 running as a windows service?  (Read 15046 times)
Offline catanirex
« on: November 30, 2007, 03:32:01 PM »
Anybody that successfully have configured Tomcat 5.5 (running as a windows service) in Genesys CME 7.5, so that Tomcat can be both monitored in SCI and started/stopped?
I have tried with the section start_stop on Annex tab (with options start_command=net start Tomcat5 and stop_command=net stop Tomcat5). This gives me error messages from the OS:  OS Error=5. Access is denied.
This usually works good with third party applications.
I would like to be able to both monitor status in SCI, and start/stop it.
Re: SCI and Tomcat 5.5 running as a windows service?
« Reply #1 on: December 03, 2007, 11:33:57 AM »
I've tried it using Genesys CME 7.2 and SCS 7.1 and it works. I was able to reproduce the error "OS Error=5" by a mistake only - creating the section "start_stop" on Options tab instead of Annex tab.
Could you post here the log of LCA?
René
Offline catanirex
« Reply #2 on: December 03, 2007, 03:39:39 PM »
Thank you for your interest :-)
I will attach a zipped document with some screen shots of configuration and LCA log.
Hope you see whats wrong!
Offline catanirex
« Reply #3 on: December 03, 2007, 04:09:21 PM »
Update:
Solved it by creating a new application of Third Part Server in CME... realised that this Tomcat was of another application type.
I guess that WFM Web is not possible to start/stop/monitor through SCI...
Luk
« Reply #4 on: April 17, 2008, 03:42:55 PM »
[quote author=catanirex link=topic=2623.msg10263#msg10263 date=1196698161]
Update:
Hey,
I'm trying to achieve the same thing. I have created an Application object in CME of type Third Party Server and I am able to start the Tomcat5.5 server as a service. Unfortunately, the status is not updated in SCI.
Do you know how to do that as well? Or anybody else  ???
Thanks a lot in advance!
Offline catanirex
« Reply #5 on: April 17, 2008, 05:21:51 PM »
Check working directory and command line on the application object in CME. Look at my screen shots in the previous message
LCA must also be running on the host.
Luk
« Reply #6 on: April 18, 2008, 08:12:50 AM »
Hey, Thank you for your quick answer!!
I attached screenshots of my CME application object as well. I tried a few things with the Command Line field but without success. Did you configure anything on the Options tab? I didn't. And on the Annex tab I only have the start_stop section.
By the way, what did you use as Application Template? I created one myself with nothing specified on Options tab or Annex tab.
Hope you can help me...
Cheers, Luk
« Reply #7 on: April 18, 2008, 09:16:49 AM »
Luk,
Your configuration in CME is wrong. It's necessary to split command line and command line arguments. Correct configuration is:
- Command line: C:\ApacheTomcat5_5\bin\tomcat5.exe
- Command Line Arguments: //RS//"Apache Tomcat" [i](<-- check that the parameters correspond to your service configuration - only part visible on the screenshot)[/i]
Let do this change and try. If not working then I would change type of your application to "Third Party Server".
Luk
« Reply #8 on: April 18, 2008, 10:16:54 AM »
Hello Rene, Catanirex and others,
AHAAA.  I found the solution. It is a nasty one!!! Really nasty!
It was not crucial to put the command line arguments in the other box. The error was that I had "Apache Tomcat" as the service name while it had to be "Tomcat5"!!!
How did I discover this? Well, from what I found online I understood that I had to put the service name behind //RS//... but the nasty thing is that this is not the Name as it appears on the Services panel of your server. What you see there is the DISPLAY name, so that's quite confusing! If you double-click the service, it becomes clear. On the General tab it first says Service name (that's the one you need to put in CME) and then it says Display name (that's the one that shows on the services panel of your server).
So, in brief the solution for this thread:
- Application Type: Third Party Server (I had this from the start)
- Command Line Arguments: //RS//Tomcat5 (<--- the Name of the service, NOT the DISPLAY name)
- create a section "start_stop" on the Annex tab with 2 subsections
    start_command = net start "Apache Tomcat"
    stop_command = net stop "Apache Tomcat"
As you can see from the latter, it is allowed to use the DISPLAY name in the net start and net stop statements...
Hope this is usefull for others, it is for me!!!
Thank's to everyone who contributed to this solution
Cheers, Luk
Offline anandtadimalla
« Reply #9 on: August 19, 2011, 03:43:50 PM »
hi,
    how to monitor tomcat using SCI in Linux. i've followed same steps as in windows but, am not able to start or stop the Tomcat application.
Regards,
AT
Offline fnunezsa
« Reply #10 on: August 20, 2011, 12:42:26 AM »
You just has to be sure that you're start_command is exactly the same as the output for the "ps -ef | grep catalina" in Linux. For example, your start_command should be something like "/bin/sh /opt/Tomcat/bin/catalina.sh start" assuming Tomcat is installed in /opt/Tomcat
« Reply #11 on: August 20, 2011, 08:37:23 AM »
Thanks for the prompt response fnunezsa...
but, still din't solved.
when i start the Tomcat application from SCI...it's trying to start the application...initializing....pending...and then getting stopped. but, when i check the same in linux server using "ps -ef|grep catalina" catalina is started.
the issue may be with SCI... b'coz on server tomcat is started, but SCI is not able to show the correct status.
these are the parameters i've configured in Tomcat Application object.
working directory: /opt/Tomcat/bin
command line: ./startup.sh
command line arguments: .
[Annex]
section:
start_stop
Sub-sections:
start_command:"/bin/sh /opt/Tomcat/bin/catalina.sh start"
stop_command:start_command:"/bin/sh /opt/Tomcat/bin/shutdown.sh start"
let me know where am going wrong.
R,
AT
« Reply #12 on: August 22, 2011, 08:58:12 AM »
any update?
« Reply #13 on: August 22, 2011, 04:48:45 PM »
Parameters "Command line" and "Command line arguments" must match to what is returned by "ps -ef|grep catalina" command.
Offline fnunezsa
« Reply #14 on: August 22, 2011, 10:32:59 PM »
would you please post the output for "ps -ef| grep catalina"?
This is definately wrong: stop_command:start_command:"/bin/sh /opt/Tomcat/bin/shutdown.sh start"
