" /> Number Translation - Genesys CTI User Forum
Author Topic: Number Translation  (Read 3503 times)
Nik
Number Translation
« on: December 21, 2007, 01:26:21 PM »
Hello.
I'm new in Genesys.
How translate source number for outbond call (ANI) to certain number? Is I'm must use outbond strategy?
Sorry for my english.
Thanks.
Offline Daimonas
  • There's a fish in every bowl.
Re: Number Translation
« Reply #1 on: December 21, 2007, 02:14:11 PM »
I hope I understand you correctly, I think you are asking how to make the call dialed equal to the ANI business attribute within Genesys?
If so, you can't with URS/outbound strategy by itself. This is a switch provided value and on the next interaction, any changes made by URS or T-Server would be over-written.
My suggestion would be to attach-user data with a key of ANI and the value you are looking for. I assume you want this for screen pop or customer lookup information?
Alternatively, you could check with your voice trunk/port network carrier and see if they have a way of inserting to ANI into the line, so it passes through the D channel and is received by the switch. I have seen this done.
Marked as best answer by on October 29, 2025, 10:09:39 PM
colobor
« Reply #2 on: December 24, 2007, 09:38:11 AM »
  • Undo Best Answer
  • Hello.
    I'm sorry for my description of problem. The question is: How I can replace internal number of agent (DN) into fixed number (for example: 7777777) in header From: of the outgoing SIP INVITE message.
